  • The difference between the walk-in test chamber and benchtop test chamber
Oct 09, 2020
The walk-in test chamber is specifically designed to perform temperature and humidity testing on products and materials to ensure it meets the certified safety and performance requirements. The walk-in test chamber is designed in different sizes along with necessary features that are necessary for testing heat, cooling, humidity endurance of your development for safety and performance. The walk-in test chamber comes in different sizes, from the small chamber that can fit on top of a table to the large room size testing chambers.
However, the benchtop test chamber (also call the small environmental chamber) is quite different from the walk-in test chamber based on its appearance and features. The benchtop test chambers are very suitable for performing both humidity and temperature tests on products and materials to ensure adequate performance and safety. Both the walk-in test chamber and benchtop test chambers serve the same purpose, which is the testing of products and materials capabilities by subjecting it to different temperature conditions for a thorough evaluation. The benchtop test chambers are very portable and small in size, making it easy to perform tests on a small amount of space. As the name sounds, the benchtop test chamber can easily fit on top of a bench or table.
What are the walk-in test chamber and benchtop test chamber used for?
The walk-in test chamber type of temperature and humidity chamber is designed for testing the capability of heat, cold, dryness, and humidity of products and materials. The walk-in test chamber comes with quality features and controls that are suitable to test products effectively under any condition. The walk-in test chamber comes in different varieties of sizes, which makes it suitable for testing large and small objects. For the large room walk-in test chambers, products and materials can also be tested in batches simultaneously, being beneficial to manufacturing industries. The walk-in test chamber can stimulate temperature during the testing process ranging from -60°C to 90°C, which can vary depending on the machine features.
Testing products with the walk-in test chamber is similar to the benchtop test chamber when it comes to machine testing features. However, for the products and materials, the benchtop test chambers are not suitable for large product testing.
Type of tests performed in the walk-in test chamber and benchtop test chamber
walk-in test chambers are used in performing testing on products that require large testing chambers. For small products, it can be subjected to batch testing inside the walk-in test chamber. The benchtop test chamber is suitable for testing small products due to its portability and small design size. However, when it comes to the type of test that both walk-in test chamber and benchtop test chamber can perform, it includes:
  • Storage test
  • Altitude test
  • Vibration test
  • Temperature and humidity tests
  • Salt spray and salt forge testing
  • etc
walk-in test chambers serve the need of performing climatic tests on complex and huge equipment that will be hard to test other test machines. Walk-in test chamber and benchtop test chambers come with high-level technology that is efficient in boosting the testing process of products.
The features of the Walk-in test chamber and benchtop test chamber
If you want to know more details, please visit here: https://belltestchamber.com/the-difference-between-the-walk-in-test-chamber-and-benchtop-test-chamber.html
Dec 24, 2020 -
https://belltestchamber.com/reducing-risks-factors-in-environmental-chambers-for-battery-testing.html
Dec 17, 2020 -
5 Qualities of the Best Environmental Test Chamber Manufacturer - Our Bell is also a good choice.
Dec 10, 2020 -
3 Questions About the Battery of Electrical Vehicles
Dec 04, 2020 -
Which is Better with New Energy Vehicle Lead-acid Battery or Lithium Battery?
Nov 25, 2020 -
Temperature Cycling Test Chamber Testing and Debugging Methods
Nov 25, 2020 -
Nov 19, 2020 -
Temperature Cycling Test Chambers: Product Stability Test When Exposed to Extreme Temperature
Nov 11, 2020 -
There is all kind of environments in nature: high temperature, low temperature, humidity, ultraviolet light, sunlight, rain, etc.
Nov 06, 2020 -
Temperature Humidity Test Chambers for Environmental Testing - Survival of The Fittest
Oct 28, 2020 -
Battery Evaluation – Testing of Electric Vehicles
4 more news from Guangdong Bell Experiment Equipment Co.,Ltd »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
The difference between the walk-in test chamber and benchtop test chamber news release has been viewed 667 times
