BMS System Controlled Object Core Knowledge – Overcharge
Oct 15, 2020
Concept overcharging, or overcharging, is a type of lithium-ion battery abuse where the charging voltage of a lithium-ion battery is too high above its charging cut-off voltage. Lithium-ion battery charging usually set charging cut-off voltage, the process needs to use constant current and constant voltage charging method to avoid overcharging the battery. However, in special circumstances, such as BMS damage, malfunction, etc. will lead to overcharging of the lithium-ion battery, resulting in battery performance damage and safety issues. Continuous overcharging at a high rate will lead to an increase in battery temperature and internal pressure, which will have a devastating effect on the performance and appearance of the battery in serious cases, such as leakage, bottom bulging, increased internal resistance of the battery, and shortened discharge time and cycle life.
The principle is well known, the difference between the positive potential and negative potential of the battery voltage. When charging, the positive potential increases, the negative potential decreases.
The reaction formula is as follows:
More details: https://belltestchamber.com/bms-system-controlled-object-core-knowledge-overcharge.html
Dec 24, 2020 -
https://belltestchamber.com/reducing-risks-factors-in-environmental-chambers-for-battery-testing.html
Dec 17, 2020 -
5 Qualities of the Best Environmental Test Chamber Manufacturer - Our Bell is also a good choice.
Dec 10, 2020 -
3 Questions About the Battery of Electrical Vehicles
Dec 04, 2020 -
Which is Better with New Energy Vehicle Lead-acid Battery or Lithium Battery?
Nov 25, 2020 -
Temperature Cycling Test Chamber Testing and Debugging Methods
Nov 25, 2020 -
Nov 19, 2020 -
Temperature Cycling Test Chambers: Product Stability Test When Exposed to Extreme Temperature
Nov 11, 2020 -
There is all kind of environments in nature: high temperature, low temperature, humidity, ultraviolet light, sunlight, rain, etc.
Nov 06, 2020 -
Temperature Humidity Test Chambers for Environmental Testing - Survival of The Fittest
Oct 28, 2020 -
Battery Evaluation – Testing of Electric Vehicles
4 more news from Guangdong Bell Experiment Equipment Co.,Ltd »
Aug 21, 2024 -
Aug 20, 2024 -
Aug 20, 2024 -
Aug 20, 2024 -
Nepcon Vietnam 2024
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
BMS System Controlled Object Core Knowledge – Overcharge news release has been viewed 771 times
