  • New Yorker Electronics Distributes BMI 604D Series of Axial Lead Aluminum Capacitors
Dec 18, 2020
New Yorker Electronics to Distribute BMI's new Mil-Spec 4-Terminal Tubular Axial Lead Aluminum Capacitors
Mil-Spec, 4-Terminal Capacitors from Barker Microfarad feature Low Inductance and Wide Temperature, Voltage and Capacitance Ranges
NORTHVALE, New Jersey, USA – New Yorker Electronics, an authorized distributor of Barker Microfarads (BMI), is distributing the manufacturer’s 4-Terminal Tubular Axial Lead Aluminum Capacitors. These capacitors are rated to Mil Version to Mil-PRF-39018/07 and an operating temperature to +105°C.
These USA-made aluminum capacitors feature an inductance limit of 2nH and a wide temperature range. New Yorker Electronics is distributing the full range of 5 to 200VDC and the 47µF to 22,000µF capacitance range. The nominal case size range is 19.050mm Ø x 41.275mm L to 25.400mm Ø x 92.075mm L.
There are four types of sleeves available in this series. The polyester sleeve is standard on this device; also available is a P.V.C. sleeve. Both of these sleeves are also available with an epoxy end seal. These seals are available for devices that are exposed to halogenated cleaning solvents, such as in cases of removing fluxes from circuit boards or degreasing tiny metal parts.
New Yorker Electronics also is distributing two other BMI Tubular Axial Lead Capacitor Series. The 601D -55°C to +105°C Tubular Axial Lead; Long Life, Low ESR; Mil Ver—Mil-PRF-39018/03 and its 53D -40 to +85°C General Purpose Large Tubular Axial Lead Capacitor.
Barker Microfarads (BMI) is a manufacturer of USA Made high quality, high reliability aluminum electrolytic capacitors. New Yorker Electronics offers its broad range of Axial- and Radial-leaded DC capacitors (in both miniature and tubular designs) as well as a full line of AC Motor Starting and AC Motor Run capacitors.
BMI offers many standard ratings as found on our products page or we can custom design parts to fit your unique application. Our DC capacitor products are typically utilized in applications such as power supplies, filtering, by-pass, coupling-decoupling, timer applications, energy storage, noise suppression, controls and instrumentation, automotive applications, telecommunications, computers, electronic lighting ballasts, and tantalum replacement.
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Aug 09, 2024 -
New Yorker Electronics Distributes BMI 604D Series of Axial Lead Aluminum Capacitors news release has been viewed 697 times
Facility Closure
