  • New Yorker Electronics Introduces New Line of ECE Industrial Control ESTOP Switches
Dec 20, 2020
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced the release of ECE’s new ECS Series of Industrial Emergency Stop ESTOP Switches. Also available in mushroom caps and LEDs, these compact switches are designed for easy installation and removal.
These switches are constructed with a detachable contact block for easy replacement and improving work efficiency. The safety design of slide locking holder is not only for easy installation and removal, but also for prevention of any inappropriate installations of the contact blocks. They are used in industrial control panels, automation equipment, medical equipment, burglary and fire alarms and other vital applications.
The new emergency stop switches have a push-lock turn reset function and are IP65 waterproof type. They are designed to resist liquids and oils for use in a variety of work environments. The short contact unit will be a space saver. These ECE switches are manufactured in accordance with the standards of UL, cUL, CE, CCC, and TUV.
Features & Benefits:
  • Push-lock turn reset function
  • Detachable contact block for easy installation and removal
  • IP65 waterproof type
  • Short contact unit design
Applications:
  • Industrial Control Panels
  • Automation Equipment
  • Medical Equipment
  • Motor Controls
  • Industrial PC & POS System
  • Sports Equipment
  • PLC & Machine Tool Control
  • Fire Alarm & Burglary Alarm System
  • Security Control Host & DV
As a franchise distributor ECE, New Yorker supplies its full line of Dip and Micro Switches, Connectors, Terminal Blocks, Relays, Chip Inductors, Chip Beads, Resettable Fuses and Optoelectronics.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
New Yorker Electronics Introduces New Line of ECE Industrial Control ESTOP Switches news release has been viewed 423 times
