  • New Yorker Electronics Distributes Streamline Avionics' Metallized Polyester Capacitors
Dec 21, 2020
New Yorker Electronics to distribute new Streamline Avionics G Series of General Purpose Metalized Polyester Film Capacitors.
SA's Round, Oval and Box Radial General Purpose Capacitors Supply Excellent Dielectric Strength and Volumetric Efficiency at Low Cost
NORTHVALE, New Jersey, USA – New Yorker Electronics has released the Z Series Metallized Polyester General Purpose Film Capacitors from Streamline Avionics (formerly Elpac Capacitors). Z Series Metallized Polyester capacitors are designed for general purpose applications where space and weight considerations are important. They are ideal for filtering, coupling or bypassing in high or low impedance circuits with AC or DC applications.
The Polyester Z Series Capacitors are used in applications that require long term stability at a relatively low cost. The self-healing characteristics of the metallized dielectric provide a very high level of reliability. The series has a temperature range of -55°C to +85°C a full rated voltage, derated linearly from +85°C to 50% at +125°C. It is available in voltages from 50V to 600V.
The Streamline Avionics Z Series supplies exceptional dielectric strength with some of the best volumetric efficiency. Terminal to terminal, they withstand 150% of rated voltage for 60 seconds through a limited resistance of 100 ohms per volt. Terminal to case, they withstand 200% of rated voltage.
Streamline has manufactured custom EMI filters and capacitors for aerospace and industry since 1962 (formerly Elpac Electronics). The manufacture EMI filters and capacitors with film, metallized polyester and metallized polypropylene materials that are rated for 50-600 volts. The company is ISO9001:2015 and AS9100D certified and its products are used in commercial and military aircraft, power generation facilities and in heavy industrial equipment.
Features & Benefits:
  • Great Volumetric Efficiency
  • Low Cost, General Purpose
  • Excellent Dielectric Strength
  • -55 C through 85 C at full rated voltage
  • 0.8% Maximum @ 1 Khz
Applications:
  • Power Generation Facilities
  • Heavy Industrial Equipment
New Yorker Electronics is franchise distributor for Streamline Avionics and supplies its full line of EMI Filters and its Film Metallized Polyester, Metallized Polypropylene and Polyester Capacitors.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Aug 09, 2024 -
New Yorker Electronics Distributes Streamline Avionics' Metallized Polyester Capacitors news release has been viewed 695 times
Solder Paste Dispensing
