  • New Yorker Electronics Releases Picker Components PC375L Low-Profile Latching PCB Power Relay
Dec 23, 2020
New Yorker Electronics to supply new Picker Components PC375L PCB Power Relay
New Power Relay Series Requires Only a 60msec Pulse, Lowering Operating Costs and Increasing Reliability
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced the release of the new Picker Components’ PC375L16 Low Profile Latching PCB Power Relay. A second source to the popular Tyco RT Relay, the Picker Power Relay is available in 3VDC to 24VDC and in single or dual coil mode latching.
This device only requires a 60msec pulse at the same power to switch. The power savings lowers operating costs and increases the reliability of the relay with the significant reduction in coil heat. The series is available in Single or Dual Coil Mode Latching. The coil power is 400mWatts to maintain contact pressure in the non-latching relay. Coil voltages range from 3 to 24VDC with a 5KV Dielectric Strength between coil and contacts. Silver Tin Oxide contacts assure high reliability. For resistive loads, the Picker Relay rates at 16 Amps at 250VAC and at 277VAC for general purpose loads.
Options for the relay include sealed or dustcover enclosures, gold plating and standard or reverse polarity. The PC375L relay is Lead Free and RoHS compliant and meets UL873 spacing. Applications for this Green Relay include Energy and Load Management, Metering and Electric Vehicles.
Picker Components manufacturers a broad line of electro-mechanical and solid state relays. As a franchise distributor, New Yorker Electronics supplies Picker Components’ full line of Relays including Power PCB Relays, General Purpose Relays, Signal Relays, Plug-In Automotive Relays, PCB Mount Automotive Relays and Solid State Relays.
Features & Benefits:
  • 16 Amps at 250 VAC Resistive Load
  • 16 Amps at 277 VAC General Purpose Load
  • Single or Dual Coil Mode Latching is available
  • Coil Voltages from 3 to 24 VDC are available
  • Silver Tin Oxide Contacts assures high reliability
  • 5 KV Dielectric Strength between Coil and Contacts
  • Meets UL873 Spacing
  • The PC375L relay is Lead Free and RoHS Compliant
  • UL approval and final ratings are pending
Applications:
  • Energy Management
  • Load Management
  • Metering
  • Electric Vehicles
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 30, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 27, 2024 -
New Yorker Electronics Releases Picker Components PC375L Low-Profile Latching PCB Power Relay news release has been viewed 538 times
