Newly Released ECE SSR offers AC and DC Outputs with a Wide Variety of Available Voltage Options
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced its release of the new Excel Cell Electronics (ECE) ESR5 series of Power Type Solid State Relays. These Solid State Relays, available with or without LED Indicators, are commonly used in security, industrial, high power equipment, HVAC and control panels. ESR5 Solid State Relays offer AC and DC outputs and have a wide variety of available voltages including 60V, 120V, 240V, 280V, 380V and 480V.
Another important feature of this series is that they are optically isolated, meaning they have an array of photo sensors isolating the input from the output side, leading to the ESR5’s low input power consumption. Other physical characteristics include its zero voltage turn-on, zero voltage turn-off to minimize EMI EMI/RFI) and its output snubber circuit protection. It also has a high surge rating to allow lamp and motor load switching.
There are several advantages of ECE’s SSRs to versus electromechanical devices, including: low power consumption, low leakage current, stable on-resistance, high reliability, extremely long life and a small size. They exhibit fast switching speeds, high vibration and shock resistance with no switching noise from contact bounce.
The ESR5 includes an input LED indicator and supplies high DV/DT and a high blocking voltage. It is also both TTL and CMOS compatible. New Yorker Electronics also supplies the optional ECE Protective Safety Cover. Being transparent, the cover allows the LED to reach full intensity without being overdriven.
Features & Benefits:
- Optically Isolated
- Input LED indicator
- High DV/DT and high blocking voltage
- Low input power consumption
- TTL and CMOS Compatible
Applications:
- Security
- Industrial
- High Power Equipment
- HVAC
- Control Panels
New Yorker Electronics is a franchise distributor of Excel Cell Electronic (ECE) and supplies its full line of Dip and Micro Switches, Connectors, Terminal Blocks, Relays, Chip Inductors, Chip Beads and Resettable Fuses.
About New Yorker Electronics
