  • New Yorker Electronics Introduces the Autec Power Systems new Industrial Desktop Power Adapter
Jan 05, 2021
New Yorker Electronics supplies Autec Class I Industrial Desktop Power Adapter nicknamed 'The Eclipse'
Autec's 'The Eclipse' Power Adapter Achieves Level VI Efficiency and is Available in Two Power Ratings
NORTHVALE, New Jersey, USA – New Yorker Electronics has introduced Autec Power Systems’ new DTXXXE Series of Industrial Desktop Power Adapters, nicknamed ‘The Eclipse’. This industrial adapter features a 100 to 240Vac universal input voltage and a Level VI efficiency rating.
The Eclipse Desktop Power Supply is a constant voltage type, class I power adapter available through New Yorker Electronics in power ratings of 60W and 90W. The 60W is available in 5V; the 90W is available in 5V, 12V, 15V, 19V, 24V and 48V. Being UL, cUL and CE certified with an earth ground pin, the industrial desktop adapter is appropriate for consumer electronics, office equipment and industrial equipment applications.
The unit features an EC60320-C14 Inlet and its safety features include: Over Voltage Protection (OVP), Over Temperature Protection (OTP), Short Circuit Protection (SCP) and Optical Line Protection (OLP). It boasts a mean time between failures (MTBF) of 405.6Khrs and no load consumption less than 0.5W while on standby. The sleek 120x52x31.5mm design houses a Molex Output Connector.
Features & Benefits:
  • Single output from 60W
  • 100-240Vac Universal input
  • Constant Voltage Type
  • Efficiency Level VI
  • No load consumption <0.5W
  • Class I Power(with earth pin)
  • OLP, OTP, SCP and OVP
  • IEC60320-C14 Inlet
  • MTBF: 405.6Khrs
Applications:
  • Consumer electronics and office equipment
  • Industrial equipment
Customization of any of Autec's power supplies to meet specific application requirements is always an option. As a franchise distributor, New Yorker Electronics supplies Autec Power Systems’ full line of Wall Mount and Desktop Adapters, LED Drivers, AutecFLEX High Power Density PSUs as well as Primary, Coin Cell and Rechargeable Battery solutions.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
New Yorker Electronics Introduces the Autec Power Systems new Industrial Desktop Power Adapter news release has been viewed 708 times
