  • New Yorker Electronics Releases Industry's First 4-Quadrant Silicon PIN Photodiode in SMD Package
Jan 05, 2021
New Yorker Electronics supplies the new Vishay Semiconductor K857PE 4-quadrant photo detector in surface-mount package with an active area of 1.6mm2
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced the introduction of Vishay’s industry first 4-Quadrant Silicon PIN Photodiode in a standard surface-mount package, qualified for automotive applications. Combining high photo sensitivity with low 0.1% electrical segment to segment crosstalk and virtually no tolerance between its segments, the Vishay Semiconductors K857PE enables a variety of sensor and control applications for the automotive, consumer and industrial markets.
This new device combines four monolithic diodes integrated into a single 4.72mm x 4.72mm x 0.8mm top-view, surface-mount package. The defined gap between the K857PE’s four radiant sensitive areas allows for reliable measurement during laser positioning. The opaque package sides eliminate stray light irradiating the photodiodes, resulting in excellent signal to noise ratio while the linear photo response enables small signal detection.
Another important feature is that the current from each of the device’s PIN diodes can be processed individually. This results in low 0.1 % electrical crosstalk and virtually no tolerance between segments.
The Vishay K857PE retains an active area of 1.6 mm2 per quadrant and provides a floor life rating of 168h, in accordance with J-STD-020. It has a wide sensitivity range from 69 nm to 1050nm, a 8.5µA reverse light current and a ± 60° angle of half sensitivity. The device is AEC-Q101 qualified, RoHS-compliant, halogen-free and Vishay Green.
Features & Benefits:
  • Four monolithic diodes integrated into a single 4.72mm x 4.72mm x 0.8mm top-view, surface-mount package
  • Active area of 1.6mm2 per quadrant
  • AEC-Q101 qualified
  • Low electrical crosstalk
  • Virtually no tolerance between segments
  • Wide sensitivity range from 690nm to 1050nm
  • 8.5µA reverse light current
  • Daylight blocking filter
  • ±60° angle of half sensitivity
  • RoHS-compliant, halogen-free, and Vishay Green
  • Floor life of 168 h in accordance with J-STD-020
Applications:
  • Small signal detection for automotive rain / light sensors
  • Industrial automation systems
  • Laser beam alignment
  • Virtual reality
Vishay Semiconductors includes the former Vishay Telefunken product lines, the former General Semiconductor product lines, the infrared component product lines acquired from Infineon Technologies, and selected product lines acquired from International Rectifier (excluding planar high-voltage MOSFETs). As a franchise distributor for Vishay Semiconductors, New Yorker Electronics supplies its full portfolio of rectifiers, fast-recovery diodes, high-power diodes and thyristors, small-signal diodes, Zener and suppressor diodes, RF transistors, optoelectronics, power modules (a combination of power diodes, thyristors, MOSFETs, and IGBTs), and automotive modules and assemblies.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Aug 01, 2024 -
JONATHAN BEAUDEAU SLANDERED!
Jul 29, 2024 -
SMTA International Technical Conference Program Announced
Jul 29, 2024 -
Jul 29, 2024 -
Murray Percival Company Expands Product Line with Representation of BIMOS ESD Seating in the Midwest
Jul 29, 2024 -
Jul 29, 2024 -
PEMTRON Announces Partnership with American Tec for Distribution in China
Jul 29, 2024 -
Jul 26, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
New Yorker Electronics Releases Industry's First 4-Quadrant Silicon PIN Photodiode in SMD Package news release has been viewed 719 times
