  • Capacitive Touch Anti-Vandal Pushbuttons are released by New Yorker Electronics
Aug 10, 2021
New Yorker Electronics supplies CIT Relay & Switch TH Series of Capacitive Touch Anti-Vandal Switch in 30-Second Hold, Momentary Switch or a Latching Switch Mounting Options
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced its release of the new TH Series of Switches from CIT Relay & Switch. The TH Capacitive Touch Anti-Vandal switch is offered in 16mm, 19mm, 22mm or 25mm and is available with 30-Second Hold, Momentary Switch or a Latching Switch mounting options.
CIT’s TH Series Capacitive Switch is available with a flush illuminated actuator with two ring size options, each with a brushed stainless steel finish. LED color and state options include single or dual LED with LED voltage choices of 5VDC, 12VDC or 24VDC and max current of 15mA. The standard UL1430 22AWG wire length is 30cm, but custom lengths are available from New Yorker Electronics.
A touch-controlled capacitive switch operates by measuring change in capacitance when depressed. When touched, the electrical charge disrupts the switch's own electrical charge, causing a change in capacitance. The CIT Relay & Switch capacitive touch TH Series is ideally suited for use in vending machines, gated community guard houses, traffic controls, industrial controls, appliances, infotainment centers and more.
The TH’s actuator is made of stainless steel with a Polycarbonate (PC) LED Lens. The 16mm and 19mm versions are available with a thick illuminated ring, the 25mm is available with a thick illuminated ring and the 22mm is available in both styles. Most come with a standard bezel, the 16mm comes in a 4.5mm-high bezel. Single LED colors include red, orange, green, blue and white available in "Off / Color" and "Color / Off" states. The Dual LED colors are designed in red-green, red-blue, blue-green, white-orange and in the reverse orders. Its dielectric strength is 250Vrms min between contacts with an insulation resistance of more than 10MΩ min @ 600VDC and an operating temperature of -40°C to 85°C.
Features & Benefits
  • Capacitive Touch
  • Vandal Proof
  • IP68 Sealing Degree
  • Ring Illumination
  • 16mm up to 25mm
  • Panel Mount
Applications
  • Vending Kiosks
  • Public Ticket Dispensers
  • Pedestrian Crosswalk Signals
  • Gated Community Security Keypad Panels
As an authorized distributor, New Yorker Electronics supplies the full CIT Relay & Switch line of Relay devices including Automotive, UL Approved, Latching Sockets and Contactors and Switch devices including Anti-Vandal, Surface Mount, Panel Mount, Illuminated, Process Sealed, Right Angle, Pushbutton, Tactile, DIP, Slide, Rocker, Toggle, Key, Circuit Breaker, Micro-Switches and Capacitive Touch Switches.
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Aug 30, 2024 -
GE IC694PWR321
Aug 30, 2024 -
GE IC697MDL940
Aug 30, 2024 -
GE IC695CPE310
Aug 30, 2024 -
GE 151X1224CFG 31F257GFOI
Aug 30, 2024 -
GE IS200WETCH1ABA
Aug 30, 2024 -
GE HE693RTD600R
Aug 30, 2024 -
GE 369-HI-R-M-0-0
Aug 30, 2024 -
GE IS215GFOIH1A
Aug 30, 2024 -
GE DS200TBPAG1ACC
Aug 30, 2024 -
GE IC697MEM715
Capacitive Touch Anti-Vandal Pushbuttons are released by New Yorker Electronics news release has been viewed 727 times
