  • Barker Microfarads Long-Life Tubular Axial Lead Capacitors are Test-rated to 2,000 Hours
Aug 27, 2021
Barker Microfarads, Tubular Axial Lead, Axial Lead Capacitors, Aluminum Capacitors, BMI, 601D, M39018/03, aluminum electrolytic capacitors, Radial-leaded DC capacitors, AC Motor Starting, AC Motor Run, motor run capacitors
New Yorker Electronics Releases the Barker Microfarads +105°C Tubular Axial Lead Aluminum Capacitors, a Mil-Spec Equivalent designed for Commercial Use
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced its release of the Barker Microfarads (BMI) 601D +105°C Tubular Axial Lead Aluminum Capacitors. Although the 601D Series is used in commercial applications, it is the 601D capacitor series is the commercial equivalent to the military series M39018/03.
As a military equivalent, these aluminum capacitors from BMI feature a wide temperature range of -55°C to +105°C and are Life Validation Test rated to 2,000 hours at +105°C. In addition to its low ESR, the BMI 601D Capacitor Series is available from New Yorker Electronics in voltages ranging from 6.3 to 300VDC working with DC surges from 8 to 350 volts. The standard capacitance tolerance is -10%/+50% and it also boasts a capacitance range of between 12µF and 33,000µF.
There are four types of sleeves available in this series. The polyester sleeve is standard on this device; also available is a P.V.C. sleeve. Both of these sleeves are also available with an epoxy end seal. These seals are available for devices that are exposed to halogenated cleaning solvents, such as in cases of removing fluxes from circuit boards or degreasing tiny metal parts.
Case sizes range from 0.625in Ø x 1.125in L to 1.00in Ø x 3.625in L with 24 options in total. They are manufactured with USA-made aluminum and axial leads with either No. 20 AWG at 0.032in or No. 18 AWG at 0.040in.
Features:
  • Wide Temperature Range
  • Military Version – Mil-PRF-39018/03
  • Long Life
  • Low ESR
Commercial Applications:
  • Aerospace
  • Audio
  • Industrial
In addition, New Yorker Electronics supplies the BMI 604D -55°C to +105°C Tubular Axial Lead; Long Life, Low ESR; Mil-PRF-39018/03 and its 53D -40 to +85°C General Purpose Large Tubular Axial Lead Capacitors.
Barker Microfarads (BMI) is a manufacturer of USA-made high quality, high reliability aluminum electrolytic capacitors. As an authorized dealer of BMI, New Yorker Electronics supplies its broad range of Axial- and Radial-leaded DC capacitors (in both miniature and tubular designs) as well as a full line of AC Motor Starting and AC Motor Run capacitors.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Aug 09, 2024 -
Barker Microfarads Long-Life Tubular Axial Lead Capacitors are Test-rated to 2,000 Hours news release has been viewed 626 times
Manufacturing Software
