  • New Yorker Electronics Releases New Innodisk Anti-Sulfuration DRAM Modules
Sep 10, 2021
New Yorker Electronics supplies the new Innodisk Industrial-grade JESD79-5 DDR5 DRAM modules with improvements in capacity, speed, voltage and ECC functions
Next Generation of 16GB & 32GB Industrial-Grade Innodisk JESD79-5 DDR5 SDRAM Offer improvements in Capacity, Speed and Voltage
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced its release of the new Innodisk Industrial-grade DDR5 DRAM modules. The JESD79-5 DDR5 SDRAM offers significant improvements in capacity, speed, voltage and ECC functions. The modules comply with all relevant JEDEC standards and are available in 16GB and 32GB capacities, as 4800MT/s.
The Innodisk DDR5 specification details up to four times as much capacity per IC, raising the maximum achievable per die capacity to 64GB and bringing the maximum potential capacity for a single DDR5 DIMM to 128GB. The Innodisk DDR5 DRAM also has a theoretical maximum transfer speed of 6400MT/s, doubling the rate of its predecessor, DDR4. In addition, the voltage has been dropped from 1.2V to 1.1V, reducing overall power consumption.
Another structural change is that power management has been moved onto the DIMM, reducing redundant power management circuitry on the motherboard for unused DIMM slots as in prior generations. For DDR5, each DIMM has two 40-bit channels (32 data bits, eight ECC bits each) for the same data total with more ECC bits. Two smaller independent channels improve memory access efficiency, leading to greater speeds with higher efficiency. New Yorker Electronics supplies the Innodisk DDR5 up to 32GB and 4800MT/s.
Less than a year since the DDR5 specification release, early adoption should happen by Q4. The new DDR5 DIMMs feature original ICs, anti-sulfuration, heat spreader and conformal coating technologies with industrial-grade reliability.
Features & Benefits:
  • Anti-Sulfuration
  • Side Fill
  • Conformal Coating
  • High Capacity and Speed (Maximum Potential Up to 128GB & 6400MT/s)
  • Fully Tested and Optimized for Stability and Performance
  • Uses Original IC to Meet Strict Industrial Standards
  • On module Power Management IC (JEDEC Standard: 1.1V)
  • Operating Environment: 0°C to +85°C
Applications:
  • Industrial/Embedded
  • Surveillance
  • Automation
  • Healthcare
New Yorker Electronics supplies Innodisk flash memory, DRAM modules and embedded peripheral products for industrial and enterprise applications.
About New Yorker Electronics
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Jun 13, 2024 -
Jun 13, 2024 -
Jun 12, 2024 -
Jun 11, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
New Yorker Electronics Releases New Innodisk Anti-Sulfuration DRAM Modules news release has been viewed 597 times
Void Free Reflow Soldering
