New Cornell Dubilier Series is its Highest Aluminum Electrolytic Capacitance Value Provides Long Life and Increased Vibration Performance
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced the release of the new Cornell Dubilier Electronics (CDE) DCMC Series of Aluminum Electrolytic Capacitors. With more capacitance and often more ripple-current capability than its best-value Type 3186 capacitor, the DCMC is the better choice for high-capacitance, power supply filters and energy storage applications such as welding equipment, UPS systems and computer hold-up power.
Made in the USA, these CDE Capacitors are constructed with an extended cathode Thermal-PakTM. The Cornell Dubilier Thermal-Pak supplies improved heat transfer as a result of a continuous heat conduction path from core to case. The extended cathode foil of the Cornell Dubilier DCMC assures cool operation with heat flow from the capacitor element to the can. In addition, it’s lightweight with increased shock and vibration performance and a longer life.
CDE now offers voltages ranging from 6.3VDC to now as high as 550V rated (600V surge) and capacitances ranging from 110UF to 3,240,000UF. They are available in standard can, stud bottom can and stud with thermal pad options with seven terminal post alternatives. CDE also offers them in polyester, PVC or no insulation.
Features & Benefits:
- Highest capacitance value
- Thermal-Pak™ extended cathode construction
Applications:
- Energy storage
- Power supplies
- UPS systems
- Power supply filters
- Welding equipment
- Computer hold-up power
As a franchise distributor for Cornell Dubilier, New Yorker Electronics supplies the full line of Aluminum Electrolytic Capacitors, AC Oil Filled Capacitors, DC Oil Filled Capacitors, Film Capacitors, MICA Capacitors, Ultracapacitors and Supercapacitors.
About New Yorker Electronics
Headquartered in Northvale, NJ, New Yorker Electronics, Co., Inc. (www.newyorkerelectronics.com) is a global franchised distributor of electronic components, value-added services, and supply chain solutions to the world’s leading OEMs and contract manufacturers in various markets. Founded in 1948, the AS9120B and ISO 9001:2015 certified company has earned a reputation for delivering superior levels of reliability and customer support while providing direct franchise access to an extensive ready-to-ship inventory of passive, inter-connect, electromechanical and Mil-Spec components, as well as semiconductor devices.
