Online PCBA Cleaning Machine HJS-8100
Mar 30, 2022
HJS-8100 is a 600mm Width Stainless Steel Net Transportation Batch PCBA On Line Cleaning Machine .
HJS-8100 is a high quality and powerful PCBA in line cleaning machine for batch PCBA.
HJS-8100 is on line, high spray pressure, longer liquid wash section, long DI water rinse, long hot air dry automatic cleaning machine.
HJS-8100 is a powerful PCBA cleaning machine which can clean flux residuals, solder balls and particles on assembly PCBA, such as: rosin flux, water-soluble flux, non-clean flux, solder paste and other organic and inorganic contaminations.
Powerful process: Pre-wash+Wash1+ Wash2+Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2. It can use to clean almost all kinds of PCBA.
Machine advantages:
1. Big quantity PCBA in line cleaning system.
2. large amount liquid spray wash method, super wash result. Thoroughly clean water-sular solder paste flux and non-clean solder paste flux on SMT or THT PCBA after welding.
3. Wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different PCBA cleaning requirements.
https://www.smt-cleaning.com/product/products-8-9.html
Dec 14, 2022 -
Electric Fixture Cleaning Machine HJS-6700
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Mis-print PCB Cleaning Machine HJS-3600
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Offline PCBA Cleaning Machine HJS-7100
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Jun 07, 2024 -
Jun 06, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Online PCBA Cleaning Machine HJS-8100 news release has been viewed 299 times
Solder Paste Dispensing
Manufacturing Software
