  • Offline PCBA Cleaning Machine HJS-7100,rosin flux, non-clean flux,water-soluble flux cleaning machine
May 08, 2022
PCB Size:
30x30mm~500x500mm
Cleaning Basket Size:
L610*W560*H100mm* 2Layers
Wash Time:
5~10min
Rinse Time:
1~2min/time
Rinse Times:
3~5times(1~99 Avaliable)
Dry Time:
20~25min
Liquid Heat Temp:
Room Temp~60
Dry Temp:
Room Temp~99
Resistivity Range:
0~18MΩ
Air Supply:
0.5Mpa, 200~400L/min
Power Supply:
AC380V. 3P,50/60Hz, 28KW
Machine Size:
1300*1200*1850( L*W*T) Mm
Weight:
600KG
Material:
SUS304 Stainless Steel
High Light:
1850mm flux cleaning machine,offline   flux cleaning machine,offline ultrasonic stencil cleaner
HJS-7100 is an off-line PCBA cleaning machine. It is a compact, energy saving and environmental protection machine.
HJS-7100 is used to wash off flux residual, solder balls, particles on PCBA, such as: rosin flux, non-clean flux, water-soluble flux. Mainly used in military, aviation, aerospace, medical, new energy, automotive electronics industries, especially suitable for small amount, multiple types PCBA cleaning.
HJS-7100 advantages:
1. Throughly clean rosin flux, water-soluble flux, non-clean flux, solder paste and other organic and inorganic contaminations on PCBA.
2. 2-layers cleaning basket: 610mm(L) ×560mm(W) × 100mm(H) x2 layers.
3. All processes are visible through a large observation window.
4 .Easy operation interface, quick setting clean parameters. Different passwords can be set.
5. Inner filter makes liquid used repeated.
6.Real-time measure DI water resistivity and monitoring cleaning effect. Resistivity range is 0~18 MΩ.
7. The remaining liquid in the pump and pipes are blown off by compressed air and flow back to cleaning tank. This function saves detergent up to 50%.
8. High standard cleanliness, ionic contamination completely meets the requirement of IIPC-610D I class.
9. SUS304 stainless steel structure, exquisite workmanship, strong and durable, acid and alkali cleaning solution corrosion resistance
HJS-7100 spec:
ITEM
SPEC
Cleaning basket size
L610xW560xH100mmx 2layers
Diluent liquid tank capacity
60L
Spray liquid tank capacity
18L
Concentrate tank capacity
30L
Cleaning time
5~20min
Rinse time
1~2 min/times
Rinse times
1~10times
Dry time
10~30min
Diluent liquid heat temp
room temp ~60ºC
PCB dry time
room temp~99ºC
Resistivity range
0~18MΩ
Liquid filter
0.2um
DI water filter
0.2um
Air filter
10um
Vent size
φ76XH50(mm)
Power supply
AC380, 3 Phases, 50/60Hz, 30KW
Air supply
0.5Mpa, 400L/Min
Machine size
L1300xW1200x1850(mm)
Machine weight
600KG
Customer Question & Answer
Q1: What is the cycle time of HJS-7100 batch cleaning machine?
A1: Total 30~45min. wash 10min+rinse 10min+dry 10~25min.
Q2: What liquid can be used in HJS-7100 to clean PCBA?
A2: It decided by electronical components and solder paste on your PCBA. Water-based PCBA cleaning liquid wash, DI water rinse.
Q3: Have many PCBAs can HJS-7100 clean in one cycle?
A3: L200*W100mm size PCBA for example, it can clean 30~40pcs.
Q4: Does the PCBAs need to bake after wash, rinse and dry process in the machine?
A4: Sure, PCBAs after clean need to put into electric oven and bake for 2 hours at 100~110 or 4hours at 80~90to make the PCBA totally dry.
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Nov 18, 2024 -
IPC Celebrates National Apprenticeship Week with a Focus on Electronics Manufacturing Excellence
Nov 18, 2024 -
IPC Introduces First Standard for In-Mold Electronics
Nov 18, 2024 -
Disruptive Innovation and Generative AI Inventor, Kevin Surace, to Keynote IPC APEX EXPO 2025
Nov 18, 2024 -
Etek Europe Expands Partnership with ITW EAE to Represent Despatch Products in the UK and Ireland
Nov 18, 2024 -
Kurtz Ersa Honors Jean Verchere's 30 Years of Dedication as He Retires
Nov 18, 2024 -
KIC Launches Game-Changing TAS Software Platform to Address Emerging Thermal Process Challenges
Nov 18, 2024 -
Nordson Test & Inspection Receives Top Honor with Prime Step-by-Step Innovation Award for SQ3000M2 System
Nov 18, 2024 -
Scienscope's New Xspection 3120 Inspects Long PCBs
Nov 18, 2024 -
PARMI USA, INC. Appoints Juan Arango as Head of Sales and Business Development to Drive U.S. Market Growth
Nov 18, 2024 -
Naprotek Welcomes Aerospace and Defense Veteran to Board of Directors
Offline PCBA Cleaning Machine HJS-7100,rosin flux, non-clean flux,water-soluble flux cleaning machine news release has been viewed 500 times
Manufacturing Software
