  • Online PCBA Cleaning Machine HJS-7800,in-line PCB cleaning machine
May 18, 2022
Product Description
HJS-7800, It is in-line, high quality, smaller footprint, batch cleaning machine.
HJS-7800 is a powerful PCBA cleaning machine which can clean flux residuals, soder balls and particles on assembly PCBA, such as: rosin flux, water-soluble flux, non-clean flux, solder paste and other organic and inorganic contaminations.
Powerful process: Pre-wash+Wash+ Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2. It can use to clean almost all kinds of PCBA.
Machine advantages:
1. Big quantity PCBA in line cleaning system.
2. Large amount liquid spray wash method, super wash result. Thoroughly clean water-sular solder paste flux and non-clean solder paste flux on SMT or THT PCBA after welding.
3. Wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different PCBA cleaning requirements.
Customer Question & Answer
Q1: What kind of PCBA can HJS-7800 clean?
A1: HJS-7800 is a 5200mm long machine, it has 1x600mm wash section with 2x8 spray rods. Normally, it can clean all PCBA by adjusting conveyor speed. For most precise PCBA, it need to adjust conveyor speed to 0.2m/min; Normally it can set to 0.3~0.4m/min.
Q2: Why is it 110KW?
A2: in wash section, it has 2x12KW heater; in pre-rinse section, it has 1x12KW heater; in Rinse section, it has 2x12KW heater; in hot air dry section, it has 2x7.5KW heater, and we also have air blowers, electric pumps.
A4: It depends on liquid itself and temperature, we install liquid cool condenser, normally 5~15L/ Hour.
machine links:
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Nov 18, 2024 -
IPC Celebrates National Apprenticeship Week with a Focus on Electronics Manufacturing Excellence
Nov 18, 2024 -
IPC Introduces First Standard for In-Mold Electronics
Nov 18, 2024 -
Disruptive Innovation and Generative AI Inventor, Kevin Surace, to Keynote IPC APEX EXPO 2025
Nov 18, 2024 -
Etek Europe Expands Partnership with ITW EAE to Represent Despatch Products in the UK and Ireland
Nov 18, 2024 -
Kurtz Ersa Honors Jean Verchere's 30 Years of Dedication as He Retires
Nov 18, 2024 -
KIC Launches Game-Changing TAS Software Platform to Address Emerging Thermal Process Challenges
Nov 18, 2024 -
Nordson Test & Inspection Receives Top Honor with Prime Step-by-Step Innovation Award for SQ3000M2 System
Nov 18, 2024 -
Scienscope's New Xspection 3120 Inspects Long PCBs
Nov 18, 2024 -
PARMI USA, INC. Appoints Juan Arango as Head of Sales and Business Development to Drive U.S. Market Growth
Nov 18, 2024 -
Naprotek Welcomes Aerospace and Defense Veteran to Board of Directors
Online PCBA Cleaning Machine HJS-7800,in-line PCB cleaning machine news release has been viewed 425 times
Manufacturing Software
