DI-10000 can make 1000L DI water per hour. DI-1000 has 3 main parts: Pre-treatment, RO reverse and Resin MB . It is a small-foot-print, 24 hour automatic working, reliable and high productivity machine.
DI Water Productivity:
1000L/Hour
DI Water Resistivity:
15MΩ
DI Water Tank Capacity:
160L
Productivity Rate:
50%
Tape Water Supply:
1.5L/Hour
Power Supply:
AC220V,1 Phase, 50/60HZ,5KW
Machine Size:
L1300xW1300xH1800
Weight:
700KG
High Light:
1000L Deionized Water Machine, UL Deionized Water Machine, 1000L water treatment machine
Machine advantages:
1. All in one integration design, compact machine.
2. Advanced DI water purify technology, RO reverse+ MB process.
3. Automatic working, DI water resistivity up to 15MΩ and stable.
4. Low electric power, low press RO film.
5. Multiple MB to improve Di water productivity and resistivity.
6. 24 hour working.
7. Machine stop immediately to protect itself once tap water supply is not enough.
8. RO system will stop once RO water tank reaches it high level position.
Customer Question & Answer
Q1: What is DI water resistivity?
A1: At the begining, It is 17MΩ. The resistivity will decline as the machine using for several months. when it is low than 2MΩ, you need to replace carbon, sand, Ro film and resins in the machine, then it will continue to supply 17MΩ DI water again. Normally, one year later you need to replace the consume materials.
Q2: What is water change RATIO?
A2: 50% tap water will change to DI water, the rest 50% will change to condense water and drain out.
