  • Electric Stencil Cleaner HJS-9500,high quality aqueous detergent stencil cleaning machine
Jul 11, 2022
Machine Description
HJS-9500 is a high quality aqueous detergent stencil cleaning machine which used to clean solder paste stencil, red glue stencil, red glue cooper stencil, mis-print PCB, large size PCBA.
The total process--aqueous detergent clean, water rinse, hot air dry is completed just in one wash chamber. The unique 4 fixed cleaning spray rods, 4fixed air knives and stencil move back and forth design makes the machine stable, reliable and super cleaning result.
HJS-9500II which can clean 2 diffirent stencils at the same time in one machine. It has totally 2 same HJS-9500 machine device which can clean 2 stencils at the same time.
Machine Features
  • 1.Suitable to clean SMT stencil, cooper mask, resin mask, misprint PCB and large size PCBA
  • 2.The unique 4 spray rods and 4 air knives fixed and stencil moves clean mechanism, more stable, quick and efficient to clean remaining solder paste, red glue and flux on SMT stencil, cooper mask, resin mask, misprint PCB and PCBA.
  • 3.The unique real-time aqueous detergent filtering system is right for precise stencil cleaning.
  • 4.State of the process is visible through a large observation window.
  • 5.Real-time measure DI water resistivity and monitoring cleaning effect.
  • 6.The remaining detergent in the pump and pipes are blown off by compressed air and flow back to cleaning tank. This function saves detergent up to 50%.
  • 7.Can used as PCBA cleaning machine to clean PCBA up to 800mmx800mm
  • 8.English color touch Panel operational interface, PLC procedure control, cleaner temperature, clean time, rinse time and rinse times, clean temperature, hot air dry time and temperature, resistivity can be set and monitored as required.
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Electric Stencil Cleaner HJS-9500,high quality aqueous detergent stencil cleaning machine news release has been viewed 359 times
