  • Pneumatic Stencil Cleaner HJS-9000,Both solvent and water-based clean liquid can be used
Jul 21, 2022
HJS is a leading smt stencil cleaner manufacturer company in China. We make pneumatic stencil cleaning machine, electric spray cleaning machine and ultrasonic stencil cleaning machine. We've installed over 800 sets in domestic and overseas customer's factories.
HJS-9000 Pneumatic Stencil Cleaner 736*736mm Solder Paste and Red Glue Stencil Automatic Cleaning Machine is used to clean SMT solder paste stencil or red glue stencil. Famous pneumatic parts, strictly produce process, patented rotation spray rods guarantee high quality stencil cleaning machine. To clean solder paste stencil is very easy for this machine. It makes your cleaning process safe, easy, cost down and efficient.
Both solvent and water-based clean liquid can be use in HJS-9000. Cleaning result is the same-100% clean. We provide high quality machines!
Machine Features:
4. Patent 360° rotation spray rods on both sides, ensure good cleaning quality and stable stencil tension.
5. Liquid recycle use, low consumption.
Machine Spec:
Item
HJS-9000 spec
Max stencil size
L750 x W750 x H40(mm)
Liquid tank
40L
Clean time
2~4min
Dry time
2~5min
Compressed air pressure
0.5~0.7Mpa
Air flow rate
400~600L/min
Clean method
360°rotat spray clean + compressed air   blow dry
Filter system
20um/5um/1um, 3 level
Machine size
L800 x W950 x H1650(mm)
Machine weight
230KG
Other accessories, please discuss with us in details.
Customer Question & Answer
Q1: Can HJS-9000 clean stencil without frame?
A1: Yes, it can, we need a stencil hold jig for this kind of stencil without frame.
Q2: Can HJS-9000 clean solder paste mis-printed PCB?
A2: Yes, it can by using a pcb holding jig.
Q3: Is HJS-9000 safety?
A3: Yes, it is, it driven by compressed-air, not using electric power, so both solvent like alcohol, IPA and aqueous liquid can be use in this machine to clean solder paste stencil.
Q4: Can this machine clean red glue printing stencil?
A4: For thickness 0.1~0.3mm red glue stencil, HJS-9000 can clean it very well; but for 3mm thickness cooper red glue stencil and plastic red glue stencil, cleaning result is not so good, especially the little holes. We recommend to use our HJS-9500 electric stencil cleaning machine, it is more powerful and many customers choose our HJS-9500 to clean thick red glue cooper stencil for its good cleaning performance.
Stencil cleaning comparison before and after cleaning:
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
SIEMENS 6EW1810-3AA
Sep 12, 2024 -
Sep 12, 2024 -
ABB DAI04 1 year warranty
Sep 12, 2024 -
LP HCW222A PLC MODULE
Sep 12, 2024 -
ABB DSRF182 57310255-AL
Sep 12, 2024 -
Sep 12, 2024 -
Pneumatic Stencil Cleaner HJS-9000,Both solvent and water-based clean liquid can be used news release has been viewed 432 times
