  • Online PCBA Cleaning Machine HJS-7800,in-line PCB cleaning machine
Jul 22, 2022
Product Description
HJS-7800, It is in-line, high quality, smaller footprint, batch cleaning machine.
HJS-7800 is a powerful PCBA cleaning machine which can clean flux residuals, soder balls and particles on assembly PCBA, such as: rosin flux, water-soluble flux, non-clean flux, solder paste and other organic and inorganic contaminations.
Powerful process: Pre-wash+Wash+ Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2. It can use to clean almost all kinds of PCBA.
Machine advantages:
1. Big quantity PCBA in line cleaning system.
2. Large amount liquid spray wash method, super wash result. Thoroughly clean water-sular solder paste flux and non-clean solder paste flux on SMT or THT PCBA after welding.
3. Wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different PCBA cleaning requirements.
Machine Spec:
S/N
Item
HJS-7800 Spec
conveyor net
500mm
2
conveyor speed
0.1~1.5m/min
3
conveyor height
900±50mm
4
conveyor direction
Left to Right
5
PCB size
L400*W500mm as max
6
PCB height
100mm as max(with component)
7
wash tank capacity
300L
8
rinse tank capacity
40L+120L+30L
9
DI water consumption
400~1000L/H
10
exhausted air
42m³
11
electric control
PLC+TP
12
Resistivity range
0~18MΩ
13
PH range
0~14
14
air supply
0.5Mpa
15
power supply
AC380V,50/60HZ, 3P,110KW
16
machine size
L5200*W1800*H1650mm
17
machine weight
2600KG
Customer Question & Answer
Q1: What kind of PCBA can HJS-7800 clean?
A1: HJS-7800 is a 5200mm long machine, it has 1x600mm wash section with 2x8 spray rods. Normally, it can clean all PCBA by adjusting conveyor speed. For most precise PCBA, it need to adjust conveyor speed to 0.2m/min; Normally it can set to 0.3~0.4m/min.
Q2: Why is it 110KW?
A2: in wash section, it has 2x12KW heater; in pre-rinse section, it has 1x12KW heater; in Rinse section, it has 2x12KW heater; in hot air dry section, it has 2x7.5KW heater, and we also have air blowers, electric pumps.
A4: It depends on liquid itself and temperature, we install liquid cool condenser, normally 5~15L/ Hour.
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Online PCBA Cleaning Machine HJS-7800,in-line PCB cleaning machine news release has been viewed 405 times
Manufacturing Software
