SMT solder paste printing machine squeegees are very hard to clean because the corners at the 2 end of them; cracks of squeegees and fixing plates are also never be cleared.SUS304 stainless steel, silver color, automatic SMT Squeegee Cleaning Machine for SMT printer HJS-3700 is an off-line, compact, energy-saving , batch cleaning SMT Squeegee cleaning machine. HJS-3700 can automatically complete the cleaning, rinsing, drying process in one chamber by just push" start" key.
Machine Features:
1. Special designed to clean solder paste, flux and other organic and inorganic contaminations on Squeegees .
2. Ultrasonic and spray clean at the same time to clean all the solder paste off from the squeegees.
3. Clean, rinse, dry process, thoroughly clean, standby and ready to use at any time.
4. 6 squeegee racks : can clean 6 600mm squeegees in one time.
5. State of the process is visible through a large observation window.
6. Clean detergent heat system heat cleaning detergent to a certain temp, raise cleaning efficiency and reduce clean time.
7. Easy operation interface, quick setting clean parameters. Different passwords can be set.
8. Inner filter makes detergent used repeated. .
9. Totally SUS304 structure, very firm and attractive.
Machine Spec:
Item
HJS-3700 Spec
Squeegee numbers
6pcs of 600mm squeegees one time, 12 pcs of 254mm one time
clean liquid tank capacity
80L
rinse water tank capacity
80L
Clean time
5~10min
Rinse time
1~2min
Dry time
10~30min
cleaning liquid heat temp
Room temp~60ºC
Dry temp
Room temp~99ºC
water temp
Room temo~60ºC
Cleaning liquid filter
1um
Rinse water filter
1um
clean/ rinse pump
1.1KW
ultrasonic power
1.2KW
Power/air supply
AC380V/50A/50HZ,30KW;0.5Mpa
Machine size
L1400 x W1300 x H1300(mm)
Machine weight
500KG
