HJS-9000II is the machine which can clean 2 different stencils at the same time in one machine. It has totally 2 same HJS-9000 machine device which can clean 2 stencils at the same time. You can use one side to clean solder paste stencil and the other side to clean red glue stencil. HJS-9000II is popular used to clean SMT solder paste or red glue stencil. Famous pneumatic parts, strictly produce process, patented rotation spray rods guarantee high quality stencil cleaning machine. To clean solder paste stencil is very easy for this machine, you can also use it to clean red glue stencil. It makes your cleaning process safe, easy, cost down and efficient.
Both solvent and water-based clean liquid can be use in HJS-9000II. Cleaning result is the same-100% clean. We provide high quality machines!
Machine Features:
4. Patent 360° rotation spray rods on both sides, ensure good cleaning quality and stable stencil tension.
5. Liquid recycle use, low consumption.
Machine Spec:
Item
HJS-9000II spec
Max stencil size
L750 x W750 x H40(mm)*2PCS
Liquid tank
40L*2PCS
Clean time
2~4min
Dry time
2~5min
Compressed air pressure
0.5~0.7Mpa
Air flow rate
400~600L/min*2PCS
Clean method
360°rotat spray clean + compressed air blow dry
Filter system
20um/5um/1um, 3 level
Machine size
L1500 x W960 x H1700(mm)
Machine weight
480KG
Other accessories, please discuss with us in details.
Customer Question & Answer
Q1: Can HJS-9000II clean stencil without frame?
A1: Yes, it can, we need a stencil hold jig for this kind of stencil without frame.
Q2: Can HJS-9000II clean solder paste mis-printed PCB?
A2: Yes, it can by using a pcb holding jig.
Q3: Is HJS-9000II safety?
A3: Yes, it is, it driven by compressed-air, not using electric power, so both solvent like alcohol, IPA and aqueous liquid can be use in this machine to clean solder paste stencil.
Q4: Can this machine clean red glue printing stencil?
A4: For thickness 0.1~0.3mm red glue stencil, HJS-9000II can clean it very well; but for 3mm thickness cooper red glue stencil and plastic red glue stencil, cleaning result is not so good, especially the little holes. We recommend to use our HJS-9500 electric stencil cleaning machine, it is more powerful and many customers choose our HJS-9500 to clean thick red glue cooper stencil for its good cleaning performance.
Stencil cleaning comparison before and after cleaning:
