  • Mis-print PCB Cleaning Machine HJS-3600,Specially designed for mis-printed PCB cleaning
Aug 29, 2022
Product Description
Specially designed for mis-printed PCB cleaning . HJS-3600 use a push and pull cleaning basket to hold PCB and wash PCB from upper and lower side. Famous pneumatic parts, strictly produce process, patent rotation spray rods guarantee you a high quality pcb machine. It make your cleaning process safe, easy, cost down and efficient.
In order to avoid  PCB cooper pad oxidized when using hot air dry, we suggest to use alcohol to clean PCB because alcohol is very easy to turn to vapor and PCB will dry naturally.
Machine Features:
4. Patent 360° rotation spray rods on both sides, ensure good cleaning quality.
5. Solvent recycle use, low consumption.
Machine Spec:
Item
HJS-3600   spec
Max   stencil size
L400   x W400 x H100(mm)
Liquid   tank
60L
Clean   time
3~10min
Dry   time
3~5min
Compressed   air pressure
0.5~0.7Mpa
Air   flow rate
400~600L/min
Clean   method
360°rotat   spray clean + compressed air blow dry
Filter   system
1mm/50um/1um,   3 level
Machine   size
L1060   x W800 x H1600(mm)
Machine   weight
260KG
Other accessories, please discuss with us in details.
Customer Question & Answer
Q1: Can HJS-3600 clean mis-printed bare PCB or one side component mounted PCB?
A1: Both bare PCB and one side component mounted PCB can be washed in this machine.
Q2: Does HJS-3600 need PCB fixture?
A2: Yes, we suggest you make your own PCB fixture to hold PCB to avoid PCB movement and scrath because solvent spray pressure.
Q3: Is HJS-3600 safe by using alcohol?
A3: Yes, it is, it driven by compressed-air, not using electric power, no need to worry about it.
Q4: Can this machine clean red glue mis-printed PCB?
A4: For thickness 0.1~0.3mm red glue PCB, HJS-3600 can clean it very well; but for over 0.5mm thickness red glue pcb, cleaning result is not so good, especially the little holes in PCB. We recommend to use our HJS-9500 electric cleaning machine, it is more powerful to do that.
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Mis-print PCB Cleaning Machine HJS-3600,Specially designed for mis-printed PCB cleaning news release has been viewed 369 times
