DI Deionized Water Machine DI-250, DI water for SMT cleaning
Sep 01, 2022
DI-250 can produce 250L DI water per hour. DI-250 has 3 main parts: Pre-treatment, RO reverse and Resin MB . It is a small-foot-print, 24 hour automatic working, reliable and high productivity machine.
Machine advantages:
1. All in one integration design, compact machine.
2. Advanced DI water purify technology, RO reverse+ MB process.
3. Automatic working, DI water resistivity up to 15MΩ and stable.
4. Low electric power, low press RO film.
5. Multiple MB to improve Di water productivity and resistivity.
6. 24 hour working.
7. Machine stop immediately to protect itself once tap water supply is not enough.
8. RO system will stop once RO water tank reaches it high level position.
Customer Question & Answer
Q1: What is DI water resistivity?
A1: At the begining, It is 17MΩ. The resistivity will decline as the machine using for several months. when it is low than 2MΩ, you need to replace carbon, sand, Ro film and resins in the machine, then it will continue to supply 17MΩ DI water again. Normally, one year later you need to replace the consume materials.
Q2: What is water change RATIO?
A2: 50% tap water will change to DI water, the rest 50% will change to condense water and drain out.
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
DI Deionized Water Machine DI-250, DI water for SMT cleaning news release has been viewed 432 times
