Sep 06, 2022
Production line layout
4000pcb surface cleaning machine is a board surface cleaning system with a new concept. Two sticky rollers adhere the dust on the PCB, use high-pressure ionic air to remove board chips, fibers, hair, powder particles and other debris, and then the sticky rollers contact the sticky paper face to face to collect the pollutants on the rollers; Ensure that the PCB surface is clean before printing, eliminate poor soldering in advance, and improve product quality.
Product structure and function
Main structure composition: the equipment is mainly composed of frame, brush mechanism, dust adhering roller mechanism, vacuum cleaner, electrostatic removal device, PCB board conveying mechanism, man-machine control display screen and electric control box
Product features
Touch screen control interface is adopted, and the operation is simple and easy to understand
The rail feeding direction can be switched at will, left → right or right → left
The front end has a brush function, which has a stronger ability to remove debris and hair
The entrance and exit of PCB board are equipped with anti-static devices to reduce the bad patch and static damage caused by static electricity in the process of mounting
It has counting function and numerical control speed display function
Dust roll paper replacement cycle reminder function
According to the high cleaning demand of PCB boards, anti-static cleaning brushes and vacuum cleaners are developed and designed to ensure efficient and stable cleaning effects.
Technical specifications
Project                             HJS-4000 specification / parameter                                           remarks
PCB size                           50x50 ~ 300x300 (LXW) mm                                                    Customized for large board
PCB thickness:                 0.5 ~ 3.2mm        Board below 0.4mm customized
Conveying height:           900 ± 25 mm
Cleaning brush                1set
Vacuum cleaner               1set
Dust sticking roller           front and rear each 1
Sticky paper                     1roll
Track direction:                 left → right or right → left (optional)
Rail fixed edge                 (front fixed or rear fixed) (optional)
Track width adjustment:   manual and automatic track width adjustment (optional)
Static eliminator:               built in        special static eliminator (optional)
Air source:                         0.4-0.5mpa
Power supply:                    AC220V, 50Hz        special voltage needs to be specified
Overall dimension:            (mm) 890x600x1400
Weight:                             140kg
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
PCBA Surface Cleaning Machine HJS-4000 news release has been viewed 286 times
