HJS-700 22L capacity solvent tank, 700*700mm big size PCBA and PCB ionic contamination tester is specially designed to test big bare PCB for PCB manufacture factory. According to IPC-TM-650 requirement and define, the test process include solvent regeneration, ions exact and ions test 3 process.
This big ionic tester adopts ROSE method to check mix ions quantity to calculate Nacl Eq/cm2 value through its high precise probes and precise analysis system.
HJS-500S is a high quality ion contamination tester for middle size PCB, PCBA and Semiconductor products after cleaning.
Iron painting material, 15L test tank bare PCB and assembly PCBA ionic contamination tester. HJS-500S adopt ROSE method to check mix ions quantity and calculate Nacl Eq/cm2 value through its high precise probes and precise analysis system. It is accurate and easy to use, the test result can be saved and printed for record.
Static ionic contamination tester 15L PCBA ionic contamination tester IPC-TM-650 standard.15L capacity solvent tank accurate and portable static PCBA ionic contamination tester, HJS-350 is specially used to accurate test the ions on the surface of PCBA and semiconductor products.HJS-350 adopt ROSE method to check mix ions quantity to calculate Nacl Eq/cm2 value through its high precise probes and precise analysis system.HJS-350 will print the test result after testing.
Machine advantages:
1. Provide an accurate, repeatable, raped method for ionic contamination test.
2. Determine the cleanliness of bare PCB and assembly PCBA.
3. Comply with current industrial specifications such as IPC-TM-650, MIL-STD-2000A,MIL-P-28809,DEF-STD-10/03,IEC...
4. Test tank specially designed for complete ionic contamination extraction.
5. Test tank changeable, tank can be made on customer's request.
6. More reasonable control mechanism to ensure accurate test.
7. Dynamic or Static test method.
8. Easy-use software, friendly interface, English/Chinese language.
Test Software features
1. Windows work environment( windows7, windows xp etc).
2. English/Chinese interface.
3. USB communication port.
4. Word or PDF report form.
5. Metric(cm)/British(inch) system.
6. Simple parameters set-up.
7. Chart, data, status on one screen.
