Machine Description:
HJS-5700 (PLC controlled confined space high pressure automatic water spray screen stripping machine) is used to erase old emulsion on screen and make the screen into blank and waiting for reuse next time. Put the screen into stripping tank outside to soften the emulsion and then put it into machine to do automatic stripping work. 2 water spray rods high pressure to clean the front and rear side of the screen. water spray back side can be turn on an shut off for normal screen and water film screen. Spray water pressure, spray time and spray rods moving speed can be edited on PLC program as needed. Water can be discharge or recycle used.
HJS-5700 also can be used to erase ghost by putting on ghost erase paste.
HJS-5700 advantages:
1. Low water cost.
2. Very good develop and strip quality.
3. One key easy operation.
4. Moving range can be set according to screen size.
5. Low water level protection function.
6. Water auto add function.
7. Spray speed and pressure easy edit.
8. Sus304 stainless steel material, acid and alkalic proof.
9. Observation window.
10. Seal cabinet, no water or mist leak out, keep workshop dry and clean.
Machine Features:
1. High quality electrical pump. High pressure water spray and recycle filtering function.
2.Totally SUS 304 structure, Strong Acid and Alkali corrosion resistance, 10 years lifespan.
3.One-key operation, developing/Stripping and dry process complete automatically according to pre-setting procedure.
4.Standard equipped water level control mechanism, automatically add water when water is not enough..
5.Standard equipped water less alarm and protection system, shut off the machine automatically to protect the pump.
6.Completely closed spray developing process, makes the ground of the workshop clean and day.
7.Super well-known electrical and pneumatic parts, perfect design, strictly produce process to ensure stability and high quality of the machine.
8.It also can be used as auto striping machine after adjusting the water jet pressure and time.
Q1: Does the screen need to immerse into stripping power tank for some time?
A1: Yes, normally, 3~30min depending on different stripping power concentration .
Q2: Can this machine strip thick screen?
A2: Yes, the water spray pressure and time can be adjusted, thick screen need 4~5min.
Q3: Can this machine strip 2 small size screen?
A3: Yes, screen size less than 500*500mm, it can strip 2 screens at the same time.
Machine pictures:
