Product Description:
HJS-4300 ink, glue liquid screen squeegee automatic cleaning machine for screen printer. It is an off-line, compact, energy-saving, batch cleaning, screen squeegee cleaning machine. all kinds of screen printing material inks, silver paste, glue... can be throughly cleaned by HJS-4300. It is an automatic running machine; wash, rinse, dry process in one chamber by just push" start" key. Inks residual was kept in filter barrel and cleaning tank.
Machine Features:
1. Special designed to clean printing ink, silver paste,glue...etc on screen squeegees .
2. Ultrasonic and spray clean at the same time to clean all the leftovers off from the squeegees.
3. Clean, rinse, dry process, thoroughly clean, standby and ready to use at any time.
4. 6 squeegee racks: can clean 4 pcs of 900mm squeegees in one time.
5. State of the process is visible through a large observation window.
6. Clean liquid heat system heat liquid to a certain temp, raise clean efficiency and reduce clean time.
7. Easy operation interface, quick setting clean parameters. Different passwords can be set.
8. Inner filter makes liquid used repeated. .
9. Totally SUS304 structure, very firm and attractive.
Machine Spec:
Item
HJS-4300 Spec
Squeegee numbers
4 pcs of 900mm squeegees one time, 12 pcs of 400mm one time
clean liquid tank capacity
100L
rinse water tank capacity
100L
Clean time
5~10min
Rinse time
1~2min
Dry time
5~15min
cleaning liquid heat temp
RT~60ºC
Dry temp
RT~99ºC
water temp
RT~60ºC
Cleaning liquid filter
1um
Rinse water filter
1um
clean/ rinse pump
1.1KW
ultrasonic power
1.7KW
Power/air supply
AC380V/50A/50HZ,30KW;0.5Mpa
Machine size
L1700 x W1400 x H1300(mm)
Machine weight
600KG
Q1: How many squeegees can HJS-4300 clean at one time?
A1: 900mm length squeegees, 6 pcs; 400mm length squeegees, 12 pcs.
Q2: How HJS-4300 can complex squeegees clean?
A2: HJS-4300 use ultrasonic cleaning and spray cleaning technology.
Q3: What is cycle time of HJS-4300?
A3: about 20 minutes.
