  • Ionic Contamination Tester,Ionic Contamination Tester for SMT,PCB Ionic Contamination Tester
Oct 14, 2022
HJS-500S is a high quality ion contamination tester for middle size PCB, PCBA and Semiconductor products after cleaning.
Iron painting material, 15L test tank bare PCB and assembly PCBA ionic contamination tester. HJS-500S adopt ROSE method to check mix ions quantity and calculate Nacl Eq/cm2 value through its high precise probes and precise analysis system. It is accurate and easy to use, the test result can be saved and printed for record.
Static ionic contamination tester 15L PCBA ionic contamination tester IPC-TM-650 standard.15L capacity solvent tank accurate and portable static PCBA ionic contamination tester, HJS-350 is specially used to accurate test the ions on the surface of PCBA and semiconductor products.HJS-350 adopt ROSE method to check mix ions quantity to calculate Nacl Eq/cm2 value through its high precise probes and precise analysis system.HJS-350 will print the test result after testing.
Machine advantages:
1. Provide an accurate, repeatable, raped method for ionic contamination test.
2. Determine the cleanliness of bare PCB and assembly PCBA.
3. Comply with current industrial specifications such as IPC-TM-650, MIL-STD-2000A,MIL-P-28809,DEF-STD-10/03,IEC...
4. Test tank specially designed for complete ionic contamination extraction.
5. Test tank changeable, tank can be made on customer's request.
6. More reasonable control mechanism to ensure accurate test.
7. Dynamic or Static test method.
8. Easy-use software, friendly interface, English/Chinese language.
Test Software features
1. Windows work environment( windows7, windows xp etc).
2. English/Chinese interface.
3. USB communication port.
4. Word or PDF report form.
5. Metric(cm)/British(inch) system.
6. Simple parameters set-up.
7. Chart, data, status on one screen.
SPEC
Item
HJS-500S
Remarks
Test method
Static
solvent level   adjustment
Yes
Sensitiveity
0.001us/cm
Solution   capacity(L)
15
Tank size(mm)
480x400x45
Sample   size(mm)
480x400x45
Heater
Yes
Max operation   temp(ºC)
45
Power supply
AC220V,50Hz,   1A
Machine   size(mm)
900x440x1100
Weight
80
Item
HJS-350
Remarks
Test method
Dynamic
Level   adjustment
Yes
Sensitiveity
0.001us/cm
15
Tank size(mm)
500x500x45
Sample   size(mm)
480x400x45
Heater
Yes
45
Power supply
AC220V,50Hz,   1A
Machine   size(mm)
900x435x1100
Weight
85
Item
HJS-700
Remarks
Test method
Dynamic
Level adjustment
Yes
Sensitiveity
0.001us/cm
22
Tank size(mm)
700x700x30
Sample size(mm)
700x700x30
Heater
Yes
45
Power supply
AC220V,50Hz, 1A
Machine size(mm)
1350x630x1400
Weight
150
Customer Question & Answer
Q1: Is this machine precise enough?
A1: Yes, we use sensor 0.001us/cm, so don't worry about it.
Q2: What standard can this tester meet?
A2: All kinds of international standard, like: MIL-P-28809, MIL-STD-2000A, DEF-STD-10/03...
Test software and PCB picture
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Nov 18, 2024 -
IPC Celebrates National Apprenticeship Week with a Focus on Electronics Manufacturing Excellence
Nov 18, 2024 -
IPC Introduces First Standard for In-Mold Electronics
Nov 18, 2024 -
Disruptive Innovation and Generative AI Inventor, Kevin Surace, to Keynote IPC APEX EXPO 2025
Nov 18, 2024 -
Etek Europe Expands Partnership with ITW EAE to Represent Despatch Products in the UK and Ireland
Nov 18, 2024 -
Kurtz Ersa Honors Jean Verchere's 30 Years of Dedication as He Retires
Nov 18, 2024 -
KIC Launches Game-Changing TAS Software Platform to Address Emerging Thermal Process Challenges
Nov 18, 2024 -
Nordson Test & Inspection Receives Top Honor with Prime Step-by-Step Innovation Award for SQ3000M2 System
Nov 18, 2024 -
Scienscope's New Xspection 3120 Inspects Long PCBs
Nov 18, 2024 -
PARMI USA, INC. Appoints Juan Arango as Head of Sales and Business Development to Drive U.S. Market Growth
Nov 18, 2024 -
Naprotek Welcomes Aerospace and Defense Veteran to Board of Directors
Ionic Contamination Tester,Ionic Contamination Tester for SMT,PCB Ionic Contamination Tester news release has been viewed 907 times
