DI Deionized Water Machine DI-250, DI water for SMT cleaning
Oct 17, 2022
Machine advantages:
1. All in one integration design, compact machine.
2. Advanced DI water purify technology, RO reverse+ MB process.
3. Automatic working, DI water resistivity up to 15MΩ and stable.
4. Low electric power, low press RO film.
5. Multiple MB to improve Di water productivity and resistivity.
6. 24 hour working.
7. Machine stop immediately to protect itself once tap water supply is not enough.
8. RO system will stop once RO water tank reaches it high level position.
Technical spec:
Item
DI-250
DI-1000
Remarks
Tap water supply
1.5T/Hour
3T/Hour
DI water productivity
250L/Hour
1000L/Hour
water tank capacity
160L
160L
15MΩ
15MΩ
Carbon+sand capacity
25L
50L
Soften resin
25L
50L
Ro film
40*40,1PCS
40*40,4PCS
MB resin
50L
50L
Power supply
AC220V,50Hz, 2.2KW
AC220V,50Hz, 5KW
Machine size(mm)
1100x110x1600
1300x1300x1800
Weight
400
700
Customer Question & Answer
Q1: What is DI water resistivity?
A1: At the begining, It is 17MΩ. The resistivity will decline as the machine using for several months. when it is low than 2MΩ, you need to replace carbon, sand, Ro film and resins in the machine, then it will continue to supply 17MΩ DI water again. Normally, one year later you need to replace the consume materials.
Q2: What is water change RATIO?
A2: 50% tap water will change to DI water, the rest 50% will change to condense water and drain out.
Dec 14, 2022 -
Electric Fixture Cleaning Machine HJS-6700
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Mis-print PCB Cleaning Machine HJS-3600
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Offline PCBA Cleaning Machine HJS-7100
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
SIEMENS 6EW1810-3AA
Sep 12, 2024 -
Sep 12, 2024 -
ABB DAI04 1 year warranty
Sep 12, 2024 -
LP HCW222A PLC MODULE
Sep 12, 2024 -
ABB DSRF182 57310255-AL
Sep 12, 2024 -
Sep 12, 2024 -
DI Deionized Water Machine DI-250, DI water for SMT cleaning news release has been viewed 801 times
