Nov 03, 2022
Production line layout
4000pcb surface cleaning machine is a board surface cleaning system with a new concept. Two sticky rollers adhere the dust on the PCB, use high-pressure ionic air to remove board chips, fibers, hair, powder particles and other debris, and then the sticky rollers contact the sticky paper face to face to collect the pollutants on the rollers; Ensure that the PCB surface is clean before printing, eliminate poor soldering in advance, and improve product quality.
https://www.smt-cleaning.com/product-category/product/fixture-cleaning-machine/
https://www.smt-cleaning.com/product-category/product/semiconductor-cleaning-machine/
https://www.smt-cleaning.com/product/pneumatic-stencil-cleaning-machine-hjs-9000ii/
https://www.smt-cleaning.com/product-category/product/stencil-cleaning-machine/
https://www.smt-cleaning.com/product/screen-cleaning-machine-hjs-5600/
https://www.smt-cleaning.com/how-is-plasma-cleaning-machine-applied-to-wafer-cleaning/
https://www.smt-cleaning.com/product/electric-stencil-cleaning-machine-hjs-9500/
Product structure and function
Main structure composition: the equipment is mainly composed of frame, brush mechanism, dust adhering roller mechanism, vacuum cleaner, electrostatic removal device, PCB board conveying mechanism, man-machine control display screen and electric control box
Product features
Touch screen control interface is adopted, and the operation is simple and easy to understand
The rail feeding direction can be switched at will, left → right or right → left
The front end has a brush function, which has a stronger ability to remove debris and hair
The entrance and exit of PCB board are equipped with anti-static devices to reduce the bad patch and static damage caused by static electricity in the process of mounting
It has counting function and numerical control speed display function
Dust roll paper replacement cycle reminder function
According to the high cleaning demand of PCB boards, anti-static cleaning brushes and vacuum cleaners are developed and designed to ensure efficient and stable cleaning effects.
https://www.smt-cleaning.com/product/pneumatic-fixture-cleaning-machine-hjs-6600/
https://www.smt-cleaning.com/product/online-pcba-cleaning-machine-hjs-8100/
https://www.smt-cleaning.com/product/di-deionized-water-machine-di-250/
https://www.smt-cleaning.com/product/waste-water-treatment-machine-rwt-1000/
https://www.smt-cleaning.com/product/offline-pcba-cleaning-machine-hjs-7100/
https://www.smt-cleaning.com/product/screen-cleaning-machine-hjs-4600/
https://www.smt-cleaning.com/product/inline-pcba-brush-cleaning-machine-hjs-7000/
https://www.smt-cleaning.com/product-category/product/ultasonic-cleaning-machine/
https://www.smt-cleaning.com/product/online-pcba-cleaning-machine-hjs-7800/
https://www.smt-cleaning.com/product/squeegee-cleaning-machine-hjs-3700/
Dec 14, 2022 -
Electric Fixture Cleaning Machine HJS-6700
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Mis-print PCB Cleaning Machine HJS-3600
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Offline PCBA Cleaning Machine HJS-7100
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
PCBA Surface Cleaning Machine HJS-4000 news release has been viewed 908 times
