The pitot-static system is a network of pressure-sensitive pipes, sensors, and instruments used to determine an aircraft’s airspeed, altitude, and more. These measurements are displayed on an instrument panel for the pilot to analyze and interpret. Such data is paramount for standard aircraft operations, allowing pilots to safely conduct an aircraft. The system consists of a pitot tube that is typically mounted on the wing of the aircraft. A small hole on the tube allows ram air pressure to enter. There are also two static ports attached to the airplane’s fuselage that are designed to measure ambient air pressure. Other instruments include air data computers, flight data recorders, and cabin pressurization controllers.
The primary means by which the pitot-static system provides critical data is by utilizing the principle of an air pressure gradient. The pitot-static system is primarily tasked with using the pitot tube or static ports to measure pressure differences, enabling the pilot to determine the speed and altitude of the aircraft. More than that, the system is responsible for providing information for the altimeter, vertical speed indicator, and aircraft airspeed indicator. The major difference among these aircraft instruments is where they receive the data from. The altimeter and vertical speed indicator acquire information from the static ports, while the airspeed indicator utilizes both the pitot tube and the static port.
The way that the pitot tube and static ports are positioned is determinative of the role that they play. The pitot tube is forward-facing and affixed to an airspeed indicator with two inputs: one for the pitot tube and one for the static ports. The airspeed indicator delivers data to the instrumental panel within the cockpit regarding the speed of the aircraft relative to the surrounding atmosphere and measures dynamic pressure. The latter can be defined as the difference between ambient air pressure and the force of air produced by an aircraft’s forward momentum. This is where it becomes clear that the static ports and pitot tube work hand-in-hand as ambient pressure is obtained from the static port.
It is important to note that as the static port measures ambient air pressure, there is potential for inaccurate readings due to the exposure to air pressure creating a false baseline. More than that, the other instruments that measure static pressure would be affected as well. This can be remedied by mounting the static ports at a location on the aircraft where minimal air pressure is generated during movement. In order to function properly, the air pressure instruments must be calibrated according to the size and shape of their respective inlets. As such, if the size of the inlet is changed or the structure is damaged, the instruments will not produce accurate readings.
Other common obstructions which can block the pitot-static inlets include: failure to remove covers, blockages from bugs and dust, and the accumulation of ice. The covers used for the pitot-static system consist of red flags with bold letters that read “remove before flight.” In the case that the covers are not removed, air cannot make its way into the lines and instruments. Of the three aforementioned obstructions, ice accumulation is the most dangerous and happens once airborne. With today’s aircraft advancements, modern models are typically equipped with electrical elements within the pitot tube that can heat and melt ice. If an aircraft is flying in warmer, drier climates, this is not a problem. As the pitot-static system is designed with various components that have limited service lives or can be damaged by outside stressors, it is important to be certain that all the parts are working properly. With this in mind, sourcing components of the highest caliber is a major priority.
If you find yourself in need of such components or other various aircraft parts, rely on Internet of NSN for all your operational needs. Peruse our ever-expanding catalogs, fill out and submit an RFQ form for your comparisons, or contact us directly if you have any questions regarding our offered services. As we are available 24/7x365, you can always count on Internet of NSN as your go-to sourcing solution.
