  • Omni Pro to distribute new Digital Potentiometer/Rheostat with Incremental Encoder & SPI Interface
May 05, 2022
Omni Pro Electronics supplies LSI/CSI 3-Terminal Digital Potentiometer/Rheostat with Incremental Encoder & SPI Interface
New LSI/CSI 3-Terminal Device with Adjustable Debounce is designed in 20K, 50K and 100K Versions
ADDISON, Texas, USA – Omni Pro Electronics has announced LSI/CSI’s release of six new additions to its extensive line of Standard ICs. Designated LS7190, LS7191, LS7192, LS7193, LS7194 and LS7195, these new devices are versions of a three-terminal digital potentiometer to replace mechanical potentiometers.
The clocks drive an internal 6-bit up/down counter with a count N ranging between 0 and 63 to correspond to 64 wiper-tap positions of a resistor chain consisting of 64 equal resistors. The LS7190 and LS7193 interfaces with quadrature clocks from incremental encoders.
The LS7191/92 and LS7194/95 interfaces with non-quadrature up (A) and down (B) clocks. A and B inputs for LS7190/91 and LS7193/94 are debounced allowing these signals to be sourced from mechanical encoders or push-button switches. A and B inputs for the LS7192 and LS7195 are not debounced so that fast clocks from electronic clock sources can be used. They supply 3 to 5 volts and are available in 20K, 50K and 100K versions.
The LSI/CSI Digital Potentiometers are used as replacements for mechanical potentiometers and for potentiometer adjustments. They can also be used for remote adjustments of instrumentation for gain, offset, time constant, line impedance matching, audio equipment volume control and more.
Features & Benefits:
  • 64 position wiper control
  • Direct interface with Incremental Encoders
  • Adjustable debounce for mechanical encoder/switch
  • Configurable to operate with non-quadrature clock
  • SPI interface for host MCU controllers
  • Supply voltage: 3 to 5 volts
  • Available in 20K, 50K, and 100K versions
  • Qualifies for automotive temperature range
  • Available in SOIC-8, SOIC-14, and TSSOP-14
Applications:
  • Replacement for mechanical potentiometer
  • Potentiometer adjustment with mechanical Incremental Encoder
  • Remote adjustment of instrumentation for gain, offset, time constant, line impedance matching, audio equipment volume control etc.
As a Franchised Distributor, Omni Pro Electronics supplies the full line of LSI/CSI Digital Potentiometers, LED Drivers, Timers and other products.
About Omni Pro Electronics
Omni Pro Electronics (https://www.omnipro.net/) of Addison, Texas, is a franchised distributor of electronic components with an inventory of industrial control and board-level components used in a broad array of industrial, commercial and aerospace/defense applications. Specializing in Interconnect, Electromechanical and Passive Components, it is a member of ECIA (Electronics Component Industry Association) and of ERAI (Electronic Resellers Association International).
Sep 13, 2022 -
Omni Pro Electronics Announces Distribution of new EBY Electro Power Terminal Blocks
Apr 06, 2022 -
Apr 06, 2022 -
Omni Pro Electronics Announces Release of EM Micro's Low Energy V5.0 Proximity Beacon Module with Accelerometer
Apr 06, 2022 -
New Yorker Electronics Announces Acquisition of Omni-Pro Electronics
Nov 18, 2024 -
IPC Celebrates National Apprenticeship Week with a Focus on Electronics Manufacturing Excellence
Nov 18, 2024 -
IPC Introduces First Standard for In-Mold Electronics
Nov 18, 2024 -
Disruptive Innovation and Generative AI Inventor, Kevin Surace, to Keynote IPC APEX EXPO 2025
Nov 18, 2024 -
Etek Europe Expands Partnership with ITW EAE to Represent Despatch Products in the UK and Ireland
Nov 18, 2024 -
Kurtz Ersa Honors Jean Verchere's 30 Years of Dedication as He Retires
Nov 18, 2024 -
KIC Launches Game-Changing TAS Software Platform to Address Emerging Thermal Process Challenges
Nov 18, 2024 -
Nordson Test & Inspection Receives Top Honor with Prime Step-by-Step Innovation Award for SQ3000M2 System
Nov 18, 2024 -
Scienscope's New Xspection 3120 Inspects Long PCBs
Nov 18, 2024 -
PARMI USA, INC. Appoints Juan Arango as Head of Sales and Business Development to Drive U.S. Market Growth
Nov 18, 2024 -
Naprotek Welcomes Aerospace and Defense Veteran to Board of Directors
Omni Pro to distribute new Digital Potentiometer/Rheostat with Incremental Encoder & SPI Interface news release has been viewed 451 times
