  • peel force tester,peel strength testing equipment,adhesive peel test machine,
Jun 27, 2023
tape peel strength tester|adhesive peel test machine|peel adhesion tester|peel test equipment|peel test method|tape peel test standard|peel force measurement
Peel force tester
Features:
  • Accord to that requirements of EIA-481 standard on peel strength test.
  • The interface is industrial flat, the software operation is simple and convenient, and the test results can't be modified, which is highly credible.
  • With screw module, the effective stroke is more than 400MM. Running without jitter and low sound is a sign of high quality.
  • It can set the sampling data to be read in time, the test results can be displayed immediately, the upper limit and the lower limit of tension can be set, the test results can be automatically judged and printed; It can store data and establish a historic database;
  • Connect with the computer tensile meter in a straight line, record the tensile force data all the time, and present the data on the screen in the form of curve in due course. The maximum, minimum, tension range, average, root mean square, standard deviation and variance of automatic tension are provided, which is convenient for data integration.
  • This software has three languages for you to choose from: Simplified Chinese, Traditional Chinese and English. It can store data and establish a historic database; It can print out electronic files in PDF format, which is convenient for the transmission of test reports.
  • https://youtu.be/vzQjLbLvrFU
Aug 21, 2023 -
HJC-007T Auto Component Taping Machine
Aug 18, 2023 -
Tape & Reel Machine with Flexible Feeder HJC-320
Aug 15, 2023 -
Semi-auto Taping Machine HJC-1000 with camera
Jun 27, 2023 -
Automatic Tube to Tray Conversion Machine HJC-550, tube to tray packaging machine, IC tube to tray
Mar 13, 2023 -
bare die tape and reel machine, wafer to tape and reel machine, wafer to waffle tray
Feb 13, 2023 -
Multifunctional IC Programming Machine HJC-3500
Jan 27, 2023 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
peel force tester,peel strength testing equipment,adhesive peel test machine, news release has been viewed 893 times
SMT Spare Parts and Feeders
SMT Feeders
