Tape & Reel Machine with Flexible Feeder HJC-320
Aug 18, 2023
Automatic Tape & Reel Machine with Flexible Feeder HJC-320
Work flow of the equipment:
manually put the bulk materials on the feeder platform,
CCD check position and pick /put them into the carrier tape cavity,       inspect the appearance by CCD,       NG collect ,         OK put carrier tape,        heat seal and collect the tape.
1. Equipment size: L2204* W960*H1957 (including warning light height);
2. Power supply: AC220V,50Hz;;
3. Air pressure: 4-6 kg/cm;
  1. Sealing temperature: set according to material and peeling strength requirements;
  2. Working environment requirements of the machine: normal temperature.
  3. SMD TAPING MACHINE https://www.hjsautomation.com/product-category/equipment/smd-tape-and-reel/
    Semi-auto Taping Machine HJC-1000 https://www.hjsautomation.com/product/semi-auto-taping-machine-hjc-1000/
    TUBE TO TRAY CONVERSION MACHINE HJC-550 https://www.hjsautomation.com/product/automatic-tube-to-tray-conversion-machine-hjc-550/
    Automatic Tape and Reel Machine with Tube Feeding HJC-007T https://www.hjsautomation.com/product/automatic-tape-and-reel-machine-with-tube-feeding-hjc-007t/
    Automatic Tape and Reel Machine with Bowl Feeding HJC-007S https://www.hjsautomation.com/product/automatic-tape-and-reel-machine-with-bowl-feeding-hjc-007s/
    Tape and Reel Machine with Rotary Tower HJC-020S https://www.hjsautomation.com/product/automatic-smd-tape-and-reel-machine-with-rotary-tower-assembly-hjc-020s/
    FLEXIBLE BOWL FEEDER TAPE AND REEL MACHINE HJC-320 https://www.hjsautomation.com/product/flexible-bowl-feeder-tape-and-reel-machine-hjc-320/
    Reel to Tray Conversion Machine HJC-880 https://www.hjsautomation.com/product/reel-to-tray-conversion-machine-hjc-880/
    Tape and Reel Machine for Tray Feeding HJC-009TR https://www.hjsautomation.com/product/automatic-tape-and-reel-machine-for-jedec-tray-feeding-hjc-009tr/
    AUTOMATIC TESTING & SORTING MACHINE https://www.hjsautomation.com/product-category/equipment/testing-and-sorting/
    Triode Lead Clipper HJC-20T https://www.hjsautomation.com/product/tube-ic-lead-clipping-and-forming-hjc-20t/
    Hall Forming Machine HJC-3072 https://www.hjsautomation.com/product/hall-ic-forming-machine-hjc-3072/
    Peel Force Tester HJT-1000 https://www.hjsautomation.com/product/peel-force-tester-hjt-1000/
    Wafer Pick and Place Machine HJC-560 https://www.hjsautomation.com/product/wafer-pick-and-place-machine-hjc-560/
    IC Testing and Sorting with Tray HJC-8801 https://www.hjsautomation.com/product/ic-testing-and-sorting-with-tray-hjc-8801/
    IC Testing and Sorting with Tube HJC-8000T https://www.hjsautomation.com/product/ic-testing-and-sorting-with-tube-hjc-8000t/
    Tape Inspection Machine HJC-IC20C https://www.hjsautomation.com/product/tape-inspection-machine-hjc-ic20c/
    Disk Type Automatic Inductor Testing and Sorting Machine HJC-3C17E https://www.hjsautomation.com/product/disk-type-automatic-inductor-testing-and-sorting-machine-hjc-3c17e/
    Detape and Retape Machine HJC-IC19C https://www.hjsautomation.com/product/detape-and-retape-machine-hjc-ic19c/
    Multifunctional IC Programming Machine HJC-3500 https://www.hjsautomation.com/product/multifunctional-ic-programming-machine-hjc-3500/
Aug 21, 2023 -
HJC-007T Auto Component Taping Machine
Aug 15, 2023 -
Semi-auto Taping Machine HJC-1000 with camera
Jun 27, 2023 -
Automatic Tube to Tray Conversion Machine HJC-550, tube to tray packaging machine, IC tube to tray
Jun 27, 2023 -
peel force tester,peel strength testing equipment,adhesive peel test machine,
Mar 13, 2023 -
bare die tape and reel machine, wafer to tape and reel machine, wafer to waffle tray
Feb 13, 2023 -
Jan 27, 2023 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
SIEMENS 6EW1810-3AA
Sep 12, 2024 -
Sep 12, 2024 -
ABB DAI04 1 year warranty
Sep 12, 2024 -
LP HCW222A PLC MODULE
Sep 12, 2024 -
ABB DSRF182 57310255-AL
Sep 12, 2024 -
Sep 12, 2024 -
Tape & Reel Machine with Flexible Feeder HJC-320 news release has been viewed 648 times
