  • New Pin and Insert Designs Improve M23 19-Pole Field Wireable Connectors
Oct 18, 2023
M23 19-Pole Field Wiareable Circular Connectors
Mencom M23 Field wireable connectors are flexible passive devices used for a wide variety of industrial signal and control applications.  The “Crimp and Poke” method of wire termination provides a quick solution where pre-molded cordsets are not readily available, or where cabling needs to be repaired.
The improved pin and insert designs make using these connectors even more effective and efficient.  A simple change to the way the pin is captivated in the insert makes wiring, and re-wiring, if necessary, a quick and easy task.  Gone is the old retention clip that could possibly be damaged when re-wiring or repairing.  A simple extraction tool can now be used to quickly remove any contact.  The pins and sockets for the M23 19-pole products accept a wire gauge range of 24-18 AWG.
Mencom M23 19-pole field wireable connectors offer rugged and reliable connections with error-free field installation.   The universal design also provides a means for shielding the cable if needed.
As a convenience, Mencom also offers a crimp tool (CCPZ-MIL) a locator tool (MCTP-V19) and the extraction tool (MCV19ES) to assist with assembly and disassembly, as well as MCV-001 to assist with the assembly of the female threaded connector.
For more information, contact the factory or visit www.mencom.com.
Jun 05, 2024 -
Apr 09, 2024 -
UNLOCK PEAK AUTOMATION EFFICIENCY WITH MENCOM AT AUTOMATE 2024
Apr 01, 2024 -
Mencom Strengthens European Presence with New Sales Office in the Netherlands
Mar 05, 2024 -
Introducing the High-Performance Plastic Junction Boxes for Demanding Environments
Dec 18, 2023 -
Mencom Corporation Expands European Presence Through Strategic Acquisition of ELIM spol. s r.o
Jul 26, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
New Pin and Insert Designs Improve M23 19-Pole Field Wireable Connectors news release has been viewed 288 times
