【Reservoir】 : Storage unit for liquids needed for cleaning nozzles.
【touch screen】 : It is used to display all the operation and operation status of the control machine .
【observe window】 : You can observe the operation in the cleaning chamber.
【Pressure Sensor】 : Real-time monitoring of machine pressure and cleaning pressure during work.
【Air pressure regulating valve】 : Used to adjust the size of the pressure.
【Emergency stop】 : In any case, press this button to stop the machine. Before starting the machine, the button must be turned clockwise button, to unlock the status.
【 Air input 】 : external access 0.4-0.65Mpa _ air pressure.
【 power input 】 : external access 220V 50H Z voltage.
【 switch 】 : The on/off button of the machine.
