  • How to choose the right AB two-component silicone epoxy resin dispensing machine?
Dec 24, 2024
To choose the right AB two-component silicone epoxy resin dispensing machine, the following aspects should be considered:
Understand Production Requirements
  • Glue Type: Ensure the machine is compatible with AB two-component silicone epoxy resin and check if it can handle the specific viscosity and density of the glue356.
  • Mixing Ratio: Different applications require different mixing ratios of AB glue. 1:1、2:1、4:1 etc,choose a machine that can accurately control the required ratio13.
  • Production Volume: For large production volumes, an automatic dispensing machine with high efficiency is preferred, such as a fully automatic AB point with XYZ manipulator. For small production volumes or occasional use, a semi-automatic machine may be sufficient123.
Evaluate Equipment Performance
  • Precision and Stability: High precision and good stability ensure consistent glue dispensing quality, reducing product defects35.
  • Automation Degree: choose manual, semi-automatic, or fully automatic machines. Fully automatic machines with PLC control systems and human-machine interfaces are more efficient and easier to operate356.
  • Mixing Effect: The machine should be able to evenly mix the two components to achieve good bonding and curing effects12.
  • Minimum Dispensing Volume: Check if the minimum dispensing volume of the machine meets the requirements of your products.
Consider Additional Functions
  • Vacuum Degassing: If your application requires bubble-free glue, choose a machine with a vacuum degassing function2.
  • Temperature Control: If the glue's performance is affected by temperature, select a machine with a temperature control system for the material barrel or pipeline2.
Brand and After-sales Service
  • Brand Reputation: Well-known brands usually have better product quality and after-sales service. You can refer to user reviews and industry evaluations to choose reliable brands35.
  • After-sales Service: Timely and effective after-sales service can quickly solve problems during equipment use and reduce production downtime35.
Budget and Cost-effectiveness
  • Budget: Set a reasonable budget according to your actual situation and choose a machine within that range35.
  • Cost-effectiveness: Consider not only the price but also the performance, quality, and after-sales service of the machine to ensure you get the best value for your money35.
Can you recommend some reliable brands of AB two-component silicone epoxy resin dispensing machines?
What is the price range of AB two-component silicone epoxy resin dispensing machines?
Are there any specific maintenance requirements for AB two-component silicone epoxy resin dispensing machines?
Dec 24, 2024 -
How to operate and maintain the AB two-component silicone epoxy resin dispensing machine of Daheng
Dec 24, 2024 -
Dec 24, 2024 -
Dec 20, 2024 -
ViTrox Welcomes Gemaddis as a New Sales Channel Partner in France
Dec 19, 2024 -
ViTrox Expands Innovation Beyond AOI, SPI, and AXI with ViE's VisionXpert Solution
Dec 11, 2024 -
New! Model WDS-900 PC Controlled BGA Rework Station
Dec 11, 2024 -
I.C.T Launches High-Flexibility SMT Line for Efficient and Scalable Electronics Manufacturing
Dec 10, 2024 -
Jabil Recognizes Koh Young with the 2024 Best Strategic Supplier Award
Dec 10, 2024 -
The Three Types of Conveyor: A Comprehensive Guide to Conveyor Rollers and More
Dec 09, 2024 -
ViTrox Expands Midwest Reach with ASC International as New Sales Channel Partner
Dec 09, 2024 -
VJ Electronix to Exhibit at SMTA Silicon Valley Expo & Tech Forum
Void Free Reflow Soldering
