  • GPD Global To Demonstrate Automatic Fluid Dispensing Systems and Conformal Coating Equipment at IPC Apex Expo
Jan 09, 2019
Full-featured Benchtop Dispense System - Catalina Series
Selective Conformal Coating System - SimpleCoat
Full-featured Benchtop Robot, Automatic Fluid Dispenser, & Conformal Coating System - Live Demonstrations
GPD Global - manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix, and R&D production - will exhibit in Booth 2915 at IPC APEX EXPO 2019 on January 29-31 in San Diego Convention Center.
Stop by Booth 2915 to see live demonstrations of machines and equipment. Experts will be there to discuss your production needs. Whether your project requires a pump for retrofitting or a fully automated dispense system, conformal coating, or component preparation, we have a solution for you.
Live Demos - Fluid Dispensing Machines and Equipment
  • Benchtop Fluid Dispense Robot - Full-featured Benchtop Dispense Robot - NEW heated work area with Underfill capability.
  • Conformal Coating System - Cost effective Conformal Coating System with Tilt and Rotate capability – NEW Advanced Spray Valve with tight edge definition and lowest possible overspray.
  • High Precision Fluid Dispensing System - High Precision Dispensing System (MAX Series) – with capabilities for microelectronics and MEMs sensors.
Live Demos - Pumps for Integration
Latest Dispense Technologies with Controllers for Integration
Full range of Latest Dispense Technologies with controllers for Integration:
  • New Time Pressure with FPC Dispensing – enhance manual process for better dispensing results
  • Jetting NCM5000 with Controller – Simplified Jetting
  • Precision Auger with Controller – Micro Volume Dispensing down to 150 µm
  • Volumetric PCD pump with Controller – Volumetric dispense pump with total fluid control, great for viscosities 0-65,000 cps, Progressive Cavity Displacement Technology
Live Demos - Thru-Hole Equipment
Component Preparation for Through-Hole Applications
  • Axial Lead Forming System (CF-8): meets exacting military standards for axial taped or bulk components while eliminating component body stress. Consistent results for components being formed either vertically or horizontally.
  • Radial Lead Forming System (CF-9): forms and cuts 2- and 3-leaded taped components, capacitors, transistors, and LEDs. This system is designed to precisely and repeatedly form standard, as well as special formed lead configurations, with consistent ease.
  • Peel Back Force Tester (PBFT): used to measure the peel back force of carrier cover tape, supplies peel force data to ensure in-spec components reels are supplied for pick & place systems.
GPD Global is an equipment manufacturer of high quality, precision, automated fluid dispensing, conformal coating, & component-prep systems. International, state-of-the-art equipment supplier for PCB assembly and semiconductor industries. Design and manufacture wide variety of Automatic Fluid Dispensing & Conformal Coating Systems. We also manufacture SMT Cover Tape Peel Tester and Component Prep equipment for Thru-Hole applications.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 07, 2017 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
GPD Global To Demonstrate Automatic Fluid Dispensing Systems and Conformal Coating Equipment at IPC Apex Expo news release has been viewed 1444 times
Facility Closure
