  • Japan Unix Can Reduce PCB Burning Issues with Optimal Laser Shape Rings
Jun 02, 2015
Optimal Laser Shape Rings.
Japan Unix, a solutions provider for manual and soldering automation, introduces laser shape rings. Choosing the best laser spot shape to fit components and land shapes can reduce circuit board problems.
Laser shapes are available in more than just the well-known circle. It is important to choose the optimal shape to fit the components and shapes. Inadvertent burning of circuit boards or other troubles can be prevented by adjusting appropriate laser shapes such as an oval (ellipse) or a ring-shape. In addition, a beam-splitting technology provides “twin-spot laser,” which enables the simultaneous soldering of two joints. In addition to oval, ring and twin-spot, Japan Unix offers laser beam spot shapes of circle, square, ring and oval ring. (The ring and oval ring shapes are patented by Japan Unix.)
Japan Unix can help customers choose the laser type most suitable to their board patterns and components. For example, if the pad has an ellipse shape, customers should expose it with the oval type. Also, if the through-hole has black resin or other components on the back, Japan Unix suggests that customers use the ring type to prevent the laser burning it.
For more information about the importance of laser shape rings, watch the following videos:
• Verification video showing how incorrect laser shapes burn components: https://www.youtube.com/watch?v=iqjpVepqWbU
• Twin beams working two components simultaneously: https://www.youtube.com/watch?v=vRWr80bnCfg
Choosing correct laser beam shapes is as important as choosing soldering tip shapes for manual soldering. To find out more information about using optimal laser shapes, visit https://www.japanunix.com/en/products/laser/shapes.php.
Japan Unix was established in 1974 in Tokyo and has specialized in the soldering automation industry since its startup. A manufacturer and integrator of robotic soldering, Japan Unix offers production systems with advanced soldering methods that provide a high-speed quality soldering solution for automotive, medical, aerospace and electronics manufacturers. The company offers a wide range of soldering robots with a strong competency in precision soldering and factory automation.
Jul 21, 2016 -
Japan UNIX Launches Robotic Soldering Modules to Automate Soldering Operations
Feb 15, 2016 -
Join Japan Unix at the IPC APEX EXPO for New Laser Soldering Solutions
Sep 22, 2015 -
Japan Unix to Exhibit Desktop Soldering Robots at SMTA Guadalajara 2015
May 26, 2015 -
Japan Unix’s Flash Soldering Series Doubles Speed with New Optical Laser Configuration
May 19, 2015 -
Optimize Laser Soldering with Japan Unix’s New Multi-Phi Technology
Jan 22, 2015 -
Jan 12, 2015 -
Japan Unix Makes Power & High-Temp Webinar Available in Japanese
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Japan Unix Can Reduce PCB Burning Issues with Optimal Laser Shape Rings news release has been viewed 1835 times
Facility Closure
