  • JNJ Industries' SmartHolder Keeps SmartWipes® Canisters Accessible
Jul 17, 2013
SuperSaturated SmartWipes feature a durable, solvent retentive material substrate that cleans effectively without leaving excess solvent behind.
JNJ Industries’ SmartHolder was designed specifically for JNJ's SuperSaturated SmartWipes® canisters, to keep them readily available and easily accessible.  The SmartHolder is made from rugged spring steel wire that expands easily for loading and unloading the canister.  The white powder coat finish provides a clean and professional look that is suitable for all professional environments ranging from an assembly line or factory floor to the office or reception area.
Each SmartHolder is equipped with a wall mounting plate on the back side as well as a bench mounting plate located on the bottom side of the holder.  The wall mounting plate also comes with a  3" x 3" adhesive pad for quick installation without the need for tools.  For use around sensitive electronic devices when anti-static requirements must be met, the unit can grounded by using a customer supplied ground strap.  Whether wall or bench mounted, SuperSaturated SmartWipes® in a SmartHolder are ideal for all work areas.
JNJ’s SuperSaturated SmartWipes are disposable cleaning wipes that are pre-saturated with a choice of application specific  cleaning solutions.  For more information on the SmartHolder or SuperSaturated SmartWipes®, visit www.jnj-industries.com.
JNJ Industries is a leading provider of consumable products for many electronic/industrial applications. JNJ’s GlobalTech® line of environmentally responsible solvents and cleaning products serve a wide range of industries including high tech, automotive, aerospace, electronics, screen printing, and industrial manufacturing. For cleaning, maintenance, rework, and polishing, JNJ’s SmartWipes® line offers application-specific packaging and materials. For more information, visit www.jnj-industries.com. JNJ’s global headquarters are located in Franklin, Massachusetts, USA.
Jun 04, 2013 -
JNJ Industries Introduces OptiSmart® Flat Panel & Touch Screen Display Cleaner System
Jan 24, 2003 -
JNJ Industries Announces 30" Metal Squeegee Blades
Oct 30, 2001 -
AquaSonic® Features Closed Loop Recycling System
Jul 13, 2001 -
Universal Tooling For MPM AP Series and Ultraprint 2000 Printers Makes Setup Simple, Repeatable, Fast
Jun 26, 2001 -
New AQS-3500 Manual Ultrasonic Stencil Cleaner
Apr 19, 2001 -
JNJ Industries Announces Major Expansion, Dynamic Growth
Sep 17, 2024 -
ViTrox Showcases Cutting-Edge VisionXpert Smart Code Readers at SMTA Penang 2024
Sep 16, 2024 -
Essemtec Wins 2024 Mexico Technology Award for Excellence in Dispensing Technology
Sep 16, 2024 -
Impossible Objects' Flagship Industrial 3D Printer, The CBAM-25 Wins 2024 Mexico Technology Award for 3D Printing
Sep 16, 2024 -
Sep 16, 2024 -
IPC White Paper Calls for Comprehensive Roadmap to Address Advanced Packaging to Board-Level Integration Challenges
Sep 16, 2024 -
Stannol Wins Two Mexico Technology Awards for Flux and Solder Wire Innovations
Sep 16, 2024 -
Author Jairek Robbins to Discuss Leadership and Legacy in the Manufacturing Industry During the Keynote Address at SMTA International and The ASSEMBLY Show
Sep 16, 2024 -
Nordson Test & Inspection Honored with Technology Award for SQ3000M2
Sep 16, 2024 -
Apollo Seiko Mexico Triumphs with the STARGATE Laser Soldering Unit at the 2024 Mexico Technology Awards
Sep 16, 2024 -
Altus Hosts Record-Breaking 'Factory of the Future' Event
JNJ Industries' SmartHolder Keeps SmartWipes® Canisters Accessible news release has been viewed 1034 times
