  • Nordson ASYMTEK Introduces Continuous Path Motion Control Software
Aug 20, 2013
CONTINUOUS PATH MOTION CONTROL
Nordson ASYMTEK, a Nordson company (NASDAQ: NDSN), a leader in dispensing, coating, and jetting technologies, has developed Continuous Path Motion Control software for jetting underfill for flip chips. The software optimizes dispense head motion, saving time and increasing units per hour (UPH). Instead of stopping to move between die, backtracking, ramping to speed, dispensing, and decelerating, the dispense head maintains a continuous speed and direction throughout the process.
When cycle time test data of 20 strips with 70 die on a strip was evaluated using Continuous Path Motion Control as compared to conventional underfill methods that use backtracking, there was about a 27% improvement in UPH with Continuous Path. This was due to a 40% dispensing cycle time savings at 15mg/sec flow rate and 95mm/sec speed. (This doesn’t include loading and unloading.) The Continuous Path increases UPH even when compared to underfill methods that don’t include backtracking because stop-and-go movements between the die are eliminated. Continuous Path Motion Control software saves 23% dispensing cycle time at 9mg/sec flow rate depending on actual die layout, dispensing conditions, flow rate, and other factors.
"An expanding number of applications are using flip chip package devices with rigid substrates and parts that are smaller and closer together,” explained Akira Morita, product development manager, Nordson ASYMTEK. “These devices have different configurations in terms of die size, die thickness, bump numbers, bump pitch, bump gap, and substrate size. This changes the amount of underfill needed and the fluid flow speed (bump gaps and die thicknesses are different). A thinner line of fluid has to be deposited because the space between the die is narrower. Continuous Path Motion Control speeds up the dispensing process for these new applications.
Read the article “Underfilling Using Continuous Path Motion Control” and see a video showing the increased speed you get at our Continuous Path Motion Control page.
May 17, 2024 -
Nordson Electronics Solutions releases the new ASYMTEK Select Coat® SL-1040 Conformal Coating System - a new standard in conformal coating excellence and reliability
Aug 14, 2023 -
Nordson's semiconductor advanced packaging solutions will be demonstrated at SEMICON Taiwan 2023
Aug 26, 2022 -
Nordson Electronics Solutions announces distributor SmartTec Nordic A/S to support ASYMTEK Products in Denmark and Norway
Sep 26, 2021 -
Jun 30, 2021 -
Jun 23, 2021 -
Apr 29, 2021 -
Boost Fluid Dispensing Throughput up to 100% with the New ASYMTEK Forte™ MAX System from Nordson Electronics Solutions
Oct 29, 2020 -
Oct 12, 2020 -
Oct 10, 2020 -
74 more news from ASYMTEK Products | Nordson Electronics Solutions »
Jun 07, 2024 -
Jun 06, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Nordson ASYMTEK Introduces Continuous Path Motion Control Software news release has been viewed 923 times
Manufacturing Software
