  • Boost Fluid Dispensing Throughput up to 100% with the New ASYMTEK Forte™ MAX System from Nordson Electronics Solutions
Apr 29, 2021
Nordson Electronics Solutions, a global leader in electronics manufacturing technologies, announces the new ASYMTEK Forte™ MAX fluid dispensing systemwith high accuracy, dual-valve jetting in two modes, and patented, real-time correction to accommodate skewed parts. Designed for high-volume electronics manufacturing, Forte MAXimproves throughput for printed circuit board and flex circuit assembly, MEMs, and electro-mechanical assemblywhen dispensing sealants, encapsulants, underfills,and precise coating.
The Forte MAX system dispenses from two identical or two different valves usinga single set of hardware. In one configuration, two high-frequency IntelliJet® Jetting Systems dispense fluid simultaneously for applications with multi-up, panelized, or patterned parts with consistent spacing. In a second configuration, two different fluids are dispensed on the same part from two different valves, such as for dam-and-fill encapsulation and in high-mix production environments.A unique skew adjustment comes with the dual-valve system so that production is not slowed by shifted parts and varied component heights.The patented real-time correction automatically adjusts for skewed parts and component height variation in the x, y, and z-axes (Nordson US Patents 9,707,584; 10,150,131; 10,737,286 and other patents pending).
One customerhas seen a 100% increase in throughputwith the Forte MAXsystem after upgrading from the popular Spectrum II with two original DispenseJet® DJ-9500 valves. During the underfilling operation, several factors contribute to the improvement: themotion control systemchecks fiducialsquicker and moves the jets faster. The real-time skew correction increases the number of good parts produced. The IntelliJet systems operate at 500 Hz, versus older jets at 200 Hz, resulting in fluid being deposited more quickly. In addition, setting up the Forte MAX is simpler and more efficient so that changeovers are easier and faster.
The integrated dual-valve service station, closed-loop process controls, and nozzle-cleaning rail reduce operator maintenance, improve productivity, and keep the dispensing process within set limits. The system runs with Canvas® dispensing software, which simplifies programming tasks. Graphical programming lets you scan a workpiece, develop your program on or offline, and simulate the dispensing results on a virtual canvas.
Nordson Electronics Solutions offers products for precision automated fluid dispensing, conformal coating, plasma surface treatment, and selective soldering. Consisting of complementary product lines – ASYMTEK, MARCH, and SELECT– we deliver to semiconductor packaging, printed circuit board assembly, and other precision assembly operations. Our passion helps customers take their processes further faster, with best-in-class technologies, dedicated global sales and support teams, and unmatched consultative applications expertise.
Nordson Corporation (NASDAQ: NDSN) is one of the world’s leading producers of precision dispensing equipment that applies adhesives, sealants, coatings, and other materials to a broad range of consumer and industrial products during manufacturing operations. The company also manufactures equipment used in the testing and inspection of electronic components as well as technology-based systems for curing and surface treatment processes. Headquartered in Westlake, Ohio, Nordson has direct operations and sales support offices in more than 30 countries.
May 17, 2024 -
Nordson Electronics Solutions releases the new ASYMTEK Select Coat® SL-1040 Conformal Coating System - a new standard in conformal coating excellence and reliability
Aug 14, 2023 -
Nordson's semiconductor advanced packaging solutions will be demonstrated at SEMICON Taiwan 2023
Aug 26, 2022 -
Nordson Electronics Solutions announces distributor SmartTec Nordic A/S to support ASYMTEK Products in Denmark and Norway
Sep 26, 2021 -
Jun 30, 2021 -
Jun 23, 2021 -
Oct 29, 2020 -
Oct 12, 2020 -
Oct 10, 2020 -
Sep 17, 2020 -
Solve your semiconductor packaging problems with Nordson ELECTRONICS SOLUTIONS at SEMICON Taiwan 2020
74 more news from ASYMTEK Products | Nordson Electronics Solutions »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Boost Fluid Dispensing Throughput up to 100% with the New ASYMTEK Forte™ MAX System from Nordson Electronics Solutions news release has been viewed 840 times
