  • Catalyst Semiconductor 128-Bit EEPROM Reduces PCB Area by 40 Percent
Apr 29, 2003
( April 25, 2003 ) - Catalyst Semiconductor (NASDAQ: CATS) today announced the 128-bit CAT24C00 serial EEPROM memory integrated circuit. New technology allows the CAT24C00 to be packaged in a compact, 5-pin SOT23 package that requires 40 percent less printed circuit board area than an MSOP package.
This small 5-pin SOT23 package is ideal for identification applications in asset management and control. An electronic serial number or traceability information is easily stored in the non-volatile, 128 bit CAT24C00. Recording product flow traceability information or an ID number requires a few bits of data. In the past, 1-2kbit EEPROMs have been used for ID applications, but these require larger packages than the CAT24C00.
The low power CAT24C00 operates from 1.8V to 5.5V with standby current under 0.9 microamperes. Data is transferred over a high-speed 400 kHz I2C serial bus. The CAT24C00 EEPROM memory is organized as 16 words of 8 bits each.
Able to support 1-million program/erase cycles and 100 year data retention, the CAT24C00 is ideal for serial number, ID tag, smart-sensor set-up and system initialization applications.
Price, Packages and Availability
The CAT24C00 is offered in 8-pin DIP, TSSOP and SO packages as well as an area saving 5-lead SOT-23 package. Automotive, extended automotive and industrial temperature range devices are offered. Lead-free, halogen-free packages are also available as an option. Prices start at $0.13 in 10,000 piece quantities. Samples are available now. Production is scheduled for June 2003.
Data sheets are available at http://www.catalyst-semiconductor.com.
Editor Notes:
1. Trademark notices: DPP is a trademark of Catalyst Semiconductor. I2C is a registered trademark of Philips Corporation. SPI is a trademark of Motorola, Inc. Microwire is a trademark of National Semiconductor.
About Catalyst Semiconductor
Founded in 1985, Catalyst Semiconductor, Inc. is headquartered in Sunnyvale, California. The Company is a developer and marketer of programmable products used in telecommunications, networking systems, computation, automotive, industrial and consumer markets. The Company designs and markets a broad range of programmable products including Flash Memories, Parallel and Serial EEPROMs with I2C, SPI and Microwire interfaces, NVRAMs, Digitally Programmable Potentiometers, Microcontroller Supervisory circuits and other programmable Mixed Signal products. Typical applications for the Company's products include optical networks, modems, wireless LANs, network cards, PC BIOS, DIMM modules, cellular telephones, digital satellite box receivers, set-top boxes and Internet routers. Catalyst's Quality Management System is ISO 9001 certified. Additional information about Catalyst Semiconductor is available on the Company's web site at http://www.catalyst-semiconductor.com.
Except for those statements that report the Company�s historical results, the statements being made are forward-looking statements. Actual results could differ materially from those projected in the forward-looking statements. Additional information concerning factors that could cause actual results to differ materially from those in the forward-looking statements is contained under the heading "Certain Factors That May Affect the Company�s Future Results of Operations" listed from time to time in Catalyst�s SEC reports including but not limited to the report on Form 10-K for the year ended April 30, 2002, and to the reports on Form 10-Q for the quarters ended July 31, 2002, October 31, 2002, and January 31, 2003
Sep 18, 2024 -
ABB NTCS04 infi90 CONTROLS MODULE TERMINATION UNIT
Sep 18, 2024 -
ABB SPCIS22 l/O Control Module
Sep 18, 2024 -
ABB SPDSM04 Module installation unit
Sep 18, 2024 -
ABB NTRO12-A Analog input Terminal
Sep 18, 2024 -
ABB SPDSO14 Digital output Module
Sep 18, 2024 -
ABB NTDI21-A Inverter Circuit Board PCB
Sep 18, 2024 -
ABB SPDSI22 Digital input Module
Sep 18, 2024 -
ABB SPDSI14 Analog input module
Sep 18, 2024 -
ABB NKAS01-15 infi 90 Termination Cable
Sep 18, 2024 -
ABB NTAI06 terminal board
Catalyst Semiconductor 128-Bit EEPROM Reduces PCB Area by 40 Percent news release has been viewed 740 times
