  • New Thermostat-Controlled PC/104 Fan Card with Temperature, Humidity and Pressure Sensors Can Boost Reliability of Embedded Computer Systems
Nov 05, 2003
PC/104 Environmental Fan Card II
SALT LAKE CITY - November 5, 2003 � Parvus� Corporation today unveiled the ThermoCool� PC/104 Environmental Fan Card II, a multi-function add-on module for PC/104 computer systems that provides temperature-controlled forced-air cooling together with environmental monitoring of humidity and pressure conditions. Pricing ranges from $187 to $224/each in volume orders of 100+ units, depending on configuration.
The board�s two (2) high efficiency, brushless fans are designed to turn on and off, responding to changing temperature conditions, while conserving power and increasing product life when not in use. In a sealed enclosure, the Environmental Fan Card II can effectively reduce or even eliminate the need for an embedded system to have outside air exchange. Air is driven in a push-pull circular cooling pattern around the fan module and adjacent PC/104 cards.
Besides providing thermal management, the Environmental Fan Card II integrates capacitive humidity and atmospheric pressure sensors, which can be used as alarm indicators of moisture and pressure changes within an enclosed PC/104 system. The humidity sensor measures from 1-99% relative humidity with instantaneous desaturation, and the board�s pressure sensor delivers a highly accurate, linear voltage output directly proportional to applied pressure (0-29 PSI) - with precise span and offset calibration, as well as temperature compensation.
This product is available in two versions � one with all three sensors (temperature, pressure, humidity) and another with a temperature sensor only. Standard features include two (2) Form C relays, two (2) digital inputs, four (4) or seven (7) analog inputs, LED indicator, configuration jumpers, and Windows� 9x/NT/2000/XP drivers and test utility. An optional cable set with an external digital temperature sensor is also available if remote fan management is desired.
ABOUT PARVUS
Parvus Corporation is a leading North American manufacturer and systems integrator of modular computer boards, enclosures, displays and embedded systems based on the PC/104 circuit board standard. Parvus offers rugged, commercial-off-the-shelf (COTS) computing solutions ideal for avionics, military, medical, industrial, and transportation OEMs. For more information, visit http://www.parvus.com or call 801.483.1533.
NOTE FOR EDITORS
See http://www.news.parvus.com for high-resolution, downloadable artwork and an MS Word copy of this announcement.
MEDIA CONTACT:
Mike Southworth,
mike_southworth@parvus.com,
(801) 483-1533,
Parvus Corporation
www.parvus.com
Jan 29, 2008 -
Parvus Mobile 802.11 Hotspot Enables Wi-Fi Trial for MBTA Passengers, First U.S. Wireless Internet Service for Commuter Rail
Jan 07, 2008 -
Parvus Selects DDC�s New MIL-STD-1553 PC/104-Plus Card for US Navy Aircraft Upgrade Program
Nov 03, 2005 -
Parvus Releases Statement on RoHS Compliance
Sep 12, 2005 -
COM-1440 PC/104-Plus 4-Port USB 2.0 Controller from Parvus Now Available with Support for uDiskonChip SSD
Aug 24, 2005 -
Parvus Announces Availability of OrbiTrak� GSM, a PC/104 Tri-Band GSM Cellular Modem Solution with 12-Channel GPS Receiver
Jul 20, 2005 -
Parvus Sponsors Students in National Autonomous Underwater Vehicle Event
Jul 20, 2005 -
Jul 11, 2005 -
Parvus Unveils Three Fanless 800MHz Pentium III PC/104-Plus CPU Modules Designed for -40C to +85C Extended Temperature
Jun 16, 2005 -
Parvus� Parent Company, Eurotech, Announces Plans for Public Offering on Italian Stock Exchange
Jun 08, 2005 -
Parvus to Unveil Military-Grade, Galvanically Isolated Power Supply for Embedded Computer Systems
39 more news from Parvus Corporation »
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 30, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 27, 2024 -
New Thermostat-Controlled PC/104 Fan Card with Temperature, Humidity and Pressure Sensors Can Boost Reliability of Embedded Computer Systems news release has been viewed 1135 times
