Get to Know Your PCB Printer Stencil Wiping Roll
May 22, 2019
Lint-Free Stencil Roll Material
While no material is entirely lint-free, there are materials that are virtually lint-free. This is an important attribute to look for in your stencil wiping roll. Contaminated PC boards are a common problem. While the contamination itself is often thought of as a mystery to the printer operator, the cause may come from the stencil wiping roll. This is largely due to the sticky solder paste and sharp edges of the stencil’s apertures.
The stencil wiping roll is supposed to clean the stencil in an attempt to prevent contamination. However, some stencil wiping rolls leave behind pieces of its material on the stencil, subsequently contaminating the PC board. When these contaminants pass through the oven, voids will occur.
Selecting a stencil cleaning roll such as the GREEN MONSTER! can help prevent damage to products, parts, and expensive equipment. GREEN MONSTER is free of weak linty paper fibers because it is comprised of coarse rayon and ESD polyester bonded by a tough proprietary formula of copolymers.
One can determine the probability of contamination with an easy test of the stencil wiping roll. The test is called the “Tape Test”. It is a quick and simple experiment that will save any company money by not having to repair contaminated boards. It will also help any company in determining which stencil wiping rolls are acceptable.
Tape Test Procedure
  1. First, cut off a piece of scotch tape or black electrical tape about 2 inches in length.
  2. Place the strip of tape along the surface of the stencil wiping fabric.
  3. Once the tape has adhered to the surface, pressure must be applied. The pressure should be applied in an even fashion. To ensure that the pressure is equally applied roll a 1,000gm calibration weight over the taped surface. If a weight of this size is not available, a seam pro (used for wallpaper seam attachment), a full can of soda or any tool that will provide equal weight distribution can be used. In some cases, simply using a finger will be acceptable.
  4. If Scotch tape is used, place it on a black surface and observe the mount of fibers pulled off with the naked eye or better yet a magnifier.  This test can easily be quantified by counting fibers and particles under magnification.
  5. For the best determination, repeat this step for front and back sides of the wiping roll’s fabric.
Important: This test is only valid when comparing fabrics.
For more tips on optimizing your PCB cleaning process, please contact us.
Aug 03, 2022 -
High-Tech Conversions Adding JNJ Industries
Apr 20, 2021 -
New and Improved GRAB EEZ Cleanroom Wipe Dispenser
Feb 09, 2021 -
Reduce Cleanroom Contamination by Using High-Quality Wipes
Jul 16, 2020 -
SMT Stencil Cleaning Roll Tape Test
Apr 02, 2020 -
Manufacturer of GREEN MONSTER Stencil Rolls Celebrates 25th Anniversary
May 22, 2019 -
Feb 19, 2018 -
Presaturated Surface Prep Wipe
May 16, 2017 -
High-Tech Conversions Adds New Presaturated Wipe Options
Sep 01, 2016 -
Contract Manufacturing and Private Labeling Solutions
Mar 28, 2016 -
ISO 5-6 ESD Cleanroom Wipes
33 more news from High-Tech Conversions »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Get to Know Your PCB Printer Stencil Wiping Roll news release has been viewed 1201 times
