  • SEHO Systems to Showcase Its SelectiveLine at SMTA International 2011
Sep 19, 2011
SelectiveLine soldering module.
SEHO North America, Inc. will showcase its SelectiveLine soldering module in Booth #237 at the upcoming SMTA International Conference & Exhibition, scheduled to take place October 18-19, 2011 at the Fort Worth Convention Center in Fort Worth, TX.
With the SelectiveLine, SEHO has implemented a modular system concept for mini-wave soldering that may be adapted to changing production conditions any time. With low production quantities, for example, only the SelectiveLine solder module is required. With increasing throughput requirements or very massive products, the unit can be individually expanded by adding coordinate fluxer modules, preheater modules or even another SelectiveLine solder module. Consequently, cycle times are significantly reduced.
Conversely, the production line can be reduced in size again with end-of-line products and falling numbers by taking modules out of the line and using them for other products.
Featuring a high-precision mini-wave process, the SelectiveLine is ideally suited for a high product mix, offering maximum flexibility. The system features a precise axis system for exact positioning of various workstations and is capable of handling either bare boards or assemblies in carriers up to 500 x 500 mm.
The automatic circuit board position correction via fiducial recognition ensures maximum precision and process reliability. Various types of misalignment, such as offset, position error and linear distortion of the circuit board, are compensated. Incorrectly positioned assemblies are detected and not soldered.
The soldering unit can be changed quickly if different alloys need to be processed. To minimize change-over times, a second soldering unit can be preheated on an external heating station prior to installation in the machine. Thus, changing to a different solder alloy only takes a few minutes.
The SelectiveLine is equipped with a modern control unit, which is very simple to operate using a color touch screen. With the cutting-edge offline teaching program, soldering programs can be taken over by the machine using a USB memory stick or network connection without any further conversion – or vice versa. The route optimization is particularly innovative. After being taught all the solder points, the program independently calculates the quickest path – to keep pure handling times to a minimum.
Additional automatic control functions include automatic solder wave height control, real quantity control for drop jet fluxers, a scanning unit to allocate the installed solder wire reel to the corresponding soldering program, and a barcode reading system.
As always, all soldering systems from SEHO are fully lead-free capable.
Since its foundation in 1973, SEHO has become the worldwide contact partner whenever soldering is involved. Company solutions are based on performance, flexibility, efficiency and technical progress. SEHO’s business activities and production organization are oriented according to the principles of sustained future-compatible development and production of machines. As a result, all applicable environmental standards are complied with meticulously. With its systems, the company provides customers with a sustained and resource economizing production facility. It continuously develops its technology in order to provide customers with a competitive advantage.
Mar 26, 2024 -
Oct 19, 2023 -
Jul 10, 2023 -
Jan 27, 2023 -
May 27, 2022 -
Dec 21, 2021 -
Nov 22, 2021 -
Oct 11, 2021 -
Mar 15, 2021 -
Feb 25, 2021 -
Free Online Seminar from SEHO and STANNOLto Discuss Water-Based Fluxes
157 more news from SEHO Systems GmbH »
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
SEHO Systems to Showcase Its SelectiveLine at SMTA International 2011 news release has been viewed 861 times
