  • A New Low VOC Flux Technology Is Available for Vintage Machines Using Foam Fluxers
Apr 26, 2013
 The Balver Zinn Group announces that Cobar Solder Products Inc. has introduced its new 95 RX Flux Series. The low VOC flux technology has been developed for vintage soldering machines that still use foam fluxers.
Most Vintage machines use a porous ceramic or plastic stone/tube (25-45 μm) that allows compressed air to fill a tower with bubbles of flux and condense/adhere to the bottom of the PCB as it passes over. Typical problems with older IPA based fluxes include spilling over the top of the board and traveling up and out the top of the plated thru-holes (PTH) and routing slots. By its nature, the aeration of the flux causes the IPA to evaporate quickly.
Cobar’s newly formulated foaming flux can foam up to ½" high, but will not creep out of the slots and PTH like the IPA based fluxes do. This is due to the influence of the water and its higher surface tension. The water content also provides very strong foaming bubbles that carry a lot of kinetic energy; this actively assists in cleaning the surfaces and gets flux in all the holes that need to accept solder. Thus, hole fill problems are no longer an issue with the new 95 RX Series.
Additionally, the 95 RX Series contains all of the modern surface chemistries to prevent issues such as solder balling, with a minimum amount of residue. The low VOC fluxes foam extremely well, even in the oldest foam fluxers, and the height can be more precisely controlled.
Just because you have a classic/vintage wave solder system, you do not have to settle for old vintage flux technology. For more information about Cobar’s new solution for the classic soldering systems, visit www.balverzinn.com or www.cobar.com.
Oct 12, 2014 -
Richard Lim Appointed to Operations Manager for Balver Zinn Singapore
Oct 07, 2014 -
Cobar Solder Products Inc. Appoints LLE Soluciones Quimicas in Mexico
Aug 25, 2014 -
Balver Zinn Group’s Area Sales Manager to Present at IPC Standard Workshop in Russia
Aug 25, 2014 -
The Balver Zinn Group to Showcase the Latest Solder Paste Technology at SMTAI
Jun 16, 2014 -
The Balver Zinn Group Introduces Mobile Web Site
Jun 02, 2014 -
Bill Yager Joins Cobar Solder Products as Director of Business Development
Feb 27, 2014 -
The Balver Zinn Group to Showcase OT2 and WW50 at APEX
Feb 25, 2014 -
Cobar Solder Products Goes to Texas for the SMTA Dallas and Houston Expos
Feb 25, 2014 -
Count On Tools Inc. Announces APEX Special
Oct 08, 2013 -
The Balver Zinn Group to Debut OT2 Solder Paste and BRILLIANT B2012 Wire at Productronica
28 more news from Cobar Solder Products Inc. »
A New Low VOC Flux Technology Is Available for Vintage Machines Using Foam Fluxers news release has been viewed 1037 times
