  • Preview for Pickering Interfaces for SEMICON West – San Francisco, CA
Jun 19, 2016
PXI and Ethernet LXI Switching Solutions and diagnostic test tools will be on Display
Pickering Interfaces, a leading provider of signal switching and simulation solutions used in electronic test and verification, will showcase their broad catalog of PXI switching and simulation and Ethernet LXI switching solutions at SEMICON West booth 5877 on July 12-14 in San Francisco, CA. These products include Pickering’s High-density LXI Matrix Modules, High-Density PXI Relays Modules, PXI RF Multiplexers, PXI Battery Simulators, and PXI & LXI Chassis. A sampling of products that Pickering will display at SEMICON West are highlighted below:
High-density LXI Single-Pole Matrix Module (60-553) – these LXI matrix modules are capable of switching up to 150VDC/100VAC or 2A (60W max) and are used for signal routing in large Automatic Test Equipment (ATE) systems. Pickering recently announced that the model 60-553-008 version of this module was selected for opens and shorts testing of semiconductor packages by Amkor Technologies, one of the world’s largest providers of contract semiconductor assembly and test services. This model supports up to 1,027 simultaneous relay closures, which was important for Amkor’s test strategy.
PXI Precision Resistor Module (40-297) – this PXI precision resistor family provides a simple solution for applications requiring accurate simulation of resistive sensors. They are available in a variety of resistance ranges and resolution capabilities that meet the needs of most functional test systems. These resistors are particularly well suited to applications such as the testing of engine control units (ECU) where resistive sensors provide information on parameters such as temperature.
PXI RF Multiplexer (40-760)this range of RF multiplexers is available in the following configurations: dual, quad and octal SP4T, single, dual and quad SP8T, single and dual SP16T and SP32T. All of the multiplexers have versions with automatic terminations to manage VSWR effects that could degrade the performance of a test system.
PXI High-density PXI Relay Module (40-100) – this high-density relay module is configured with 83 SPDT relays, is designed for applications requiring a higher density 2 Amp alternative to Pickering’s current 52 SPDT module (model 40-139). The module is suitable for applications requiring medium power switching with very high density. It features a 2 Amp current capacity and voltages to 200VDC/140VAC. Connections are made via a front panel mounted 500-pin SEARAY high-density connector.
Also highlighted in the booth will be Pickering’s new Switching System Management Tools:
  • Signal Routing Software – Pickering’s new signal routing software simplifies signal routing through switching systems and speeds up the development of switching system software. This software supports Pickering's switching modules and the interconnection between these products.
  • eBIRST™ Switching System Test Tools – new test tools can quickly test Pickering’s switching systems and identify the faulty relays. Once identified the tools then display a graphical representation of the switching system PCB assembly, highlighting the relays that need to be replaced.
Pickering Interfaces stands behind all of their manufactured products with a standard three-year warranty and guaranteed long-term product support. Pricing and availability information is supplied on their website at www.pickeringtest.com.
Pickering will co-exhibit with their sister company, Pickering Electronics. Pickering Electronics designs and manufactures high quality reed relays, intended principally for use in Instrumentation and Test Equipment. Learn more at www.pickeringrelay.com.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Preview for Pickering Interfaces for SEMICON West – San Francisco, CA news release has been viewed 1028 times
