  • Engineered Material Systems Introduces Low-Cost Conductive Adhesive for Die Attach Applications
Oct 22, 2013
Engineered Material Systems, a leading global supplier of electronic materials for circuit assembly applications, debuts its CA-165 Low-Cost Conductive Adhesive designed for chip-on-board or general die attach applications in circuit assembly, photonics or camera modules.
ECM CA-165 is approximately half the cost of a pure silver-filled die attach adhesive, has a moderate glass transition temperature (Tg) and modulus. CA-165 has an optimized rheology for needle dispensing by time-pressure, auger or positive displacement, and is modified to provide conductivity stability during damp heat testing on tin, silver and copper surfaces.
CA-165 is the latest addition to Engineered Material Systems’ extensive line of electronic materials for semiconductor, circuit assembly, photovoltaic, printer head, camera module, disk drive and photonic applications.
For more information about the CA-165 Low Cost Electrically Conductive Adhesive or to learn how Engineered Material Systems can define, develop and create an engineered material solution that is right for your company, visit www.emsadhesives.com.
Engineered Materials Systems, Inc. (EMS) technology focus is on electronic materials for semiconductor, circuit assembly, photovoltaic, printer head, camera module, disk drive and photonics assembly product lines. The company creates continual improvements that will guide its customers into the future.
For more information, visit www.emsadhesives.com.
Dec 04, 2019 -
Jun 15, 2019 -
May 13, 2019 -
Apr 15, 2019 -
Feb 21, 2019 -
Jan 15, 2019 -
Sep 27, 2018 -
Sep 13, 2018 -
Sep 05, 2018 -
Jun 11, 2018 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
